Versuch mal das:
Code Alles anzeigen>D scnt=0 res=0 >B =>sensor53 r >F ;100ms iterations scnt+=1 switch scnt case 10 ;300 baudrate res=sml(1 0 300) res=sml(1 1 "00000000000000000000000") res=sml(1 1 "0000000000000000000000") res=sml(1 1 "2F3F210D0A") ;\?!CRLF ;case 7 res=sml(1 0 2400) case 6000 scnt=0 ends >M 1 +1,3,o,16,2400,LGUH50,1 1,6.8(@1,Zählerstand,kWh,waermemenge,0 #
Danke. Hier ist der Output:
16:23:22.109 script compressed to 252 bytes = 68 %
16:23:22.111 Script: nv=2, tv=0, vns=9, vmem=47, smem=2560
16:23:22.113 Script: performs "sensor53 r"
16:23:22.127 SNS: Hardware Serial
16:23:22.133 MQT: stat/tasmota_FA3251/RESULT = {"Time":"2023-02-13T16:23:22","SML":{"CMD":"restart"}}
16:23:52.671 CMD: sensor53 d1
16:23:52.678 MQT: stat/tasmota_FA3251/RESULT = {"Time":"2023-02-13T16:23:52","SML":{"CMD":"dump: 1"}}
16:27:04.374 MQT: tele/tasmota_FA3251/STATE = {"Time":"2023-02-13T16:27:04","Uptime":"0T01:55:12","UptimeSec":6912,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzLu","BSSId":"3C:A6:2F:56:5E:2E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:05"}}
16:27:04.380 MQT: tele/tasmota_FA3251/SENSOR = {"Time":"2023-02-13T16:27:04","LGUH50":{"waermemenge":0}}
16:32:04.392 MQT: tele/tasmota_FA3251/STATE = {"Time":"2023-02-13T16:32:04","Uptime":"0T02:00:12","UptimeSec":7212,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzLu","BSSId":"3C:A6:2F:56:5E:2E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-42,"LinkCount":1,"Downtime":"0T00:00:05"}}
16:32:04.398 MQT: tele/tasmota_FA3251/SENSOR = {"Time":"2023-02-13T16:32:04","LGUH50":{"waermemenge":0}}
16:37:04.379 MQT: tele/tasmota_FA3251/STATE = {"Time":"2023-02-13T16:37:04","Uptime":"0T02:05:12","UptimeSec":7512,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzLu","BSSId":"3C:A6:2F:56:5E:2E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:05"}}
16:37:04.385 MQT: tele/tasmota_FA3251/SENSOR = {"Time":"2023-02-13T16:37:04","LGUH50":{"waermemenge":0}}
Der Lesekopf sitzt mit dem USB Stecker nach oben auf dem Zähler.
