Vermutlich hast du telePeriod auf 10 Sekunden eingestellt.
Shelly Plug Plus S - ESP32-DevKit - Tasmota flash nicht möglich !
bigking94 -
15. September 2023 um 17:17 -
Das stimmt, Danke
Jetzt steht es auf 300 :
Alles anzeigen00:00:00.003 HDW: ESP32-U4WDH-D 00:00:00.142 UFS: FlashFS mounted with 392 kB free 00:00:00.179 CFG: Loaded from File, Anzahl 454 00:00:00.188 QPC: Count 1 00:00:00.354 BRY: Berry initialized, RAM used=4505 bytes 00:00:00.485 CFG: Energy loaded from file 00:00:00.486 NRG: Init driver 1 00:00:00.496 Projekt tasmota - Shelly Version 13.1.0(tasmota32)-2_0_11(2023.08.15 08:06:52) 00:00:00.802 TAP: Loaded Tasmota App 'Partition_Wizard.tapp' 00:00:01.739 BRY: Successfully loaded 'autoexec.be' 00:00:02.961 WIF: verbinden mit AP1 FRITZ!Box 7590 OG Channel 6 BSSId 1C:ED:6F:B6:30:94 in Modus 11n als tasmota-E692B8-4792... 00:00:03.781 WIF: verbunden 18:50:08.026 HTP: Web-Server aktiv bei tasmota-E692B8-4792 mit IP-Adresse 192.168.10.148 18:50:08.031 UPP: Multicast (wieder-)verbunden 18:50:08.034 RSL: INFO1 = {"Info1":{"Module":"Shelly Plus Plug S","Version":"13.1.0(tasmota32)","FallbackTopic":"cmnd/DVES_E692B8_fb/","GroupTopic":"cmnd/tasmotas/"}} 18:50:08.053 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-E692B8-4792","IPAddress":"192.168.10.148","IP6Global":"2003:ec:3720:5800:8264:6fff:fee6:92b8","IP6Local":"fe80::8264:6fff:fee6:92b8"}} 18:50:08.071 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":59}} 18:50:08.077 RSL: RESULT = {"POWER1":"OFF"} 18:50:08.079 RSL: POWER1 = OFF 18:50:08.080 RSL: RESULT = {"POWER2":"OFF"} 18:50:08.081 RSL: POWER2 = OFF 18:50:10.826 RSL: RESULT = {"POWER1":"ON"} 18:50:10.828 RSL: POWER1 = ON 18:50:12.643 RSL: RESULT = {"POWER2":"ON"} 18:50:12.644 RSL: POWER2 = ON 18:50:12.805 QPC: Reset 18:50:12.815 RSL: STATE = {"Time":"2023-09-25T18:50:12","Uptime":"0T00:00:07","UptimeSec":7,"Heap":85,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":45,"MqttCount":0,"Berry":{"HeapUsed":25,"Objects":343},"POWER1":"ON","POWER2":"ON","Dimmer":100,"Color":"FF0006","HSBColor":"359,100,100","Channel":[100,0,2],"Scheme":0,"Width":1,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 OG","BSSId":"1C:ED:6F:B6:30:94","Channel":6,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":1,"Downtime":"0T00:00:02"}} 18:50:12.874 RSL: SENSOR = {"Time":"2023-09-25T18:50:12","ANALOG":{"Temperature1":4.9},"ENERGY":{"TotalStartTime":"2023-09-22T17:21:52","Total":0.080,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":2,"Current":0.000},"TempUnit":"C"} 18:50:13.847 RSL: RESULT = {"POWER2":"OFF"} 18:50:13.848 RSL: POWER2 = OFF 18:50:15.079 RSL: RESULT = {"POWER1":"OFF"} 18:50:15.081 RSL: POWER1 = OFF -
