Es gibt was neues vom Shelly 1
https://shelly.cloud/product/wifi-s…m-switch-relay/
Description
- Intelligent On/Off
- Power Supply: 110-230V ±10%, 50/60Hz AC
- Compatible with all major international voltage standards.
- Maximum load current per output: 16A 110-265V, 50/60Hz AC
- Maximum load current per output: 16A 24 – 60V DC
- Complies with the following EU standards:
- RE Directive 2014/53/EU
- LVD 2006/95/WE
- EMC 2004/108/WE
- RoHS2 2011/65/UE
- Operational temperature: -40 to + 40 °C
- Dimensions (LxWxH): 41 x 36 x 17 mm
- Minimum mounting opening: Ø ≥ 50mm
- Radio signal power: 1mW
- Wireless/WiFi Protocol: 802.11 b/g/n
- Radio frequency: 2400 – 2500 MHz
- Range: up to 50 m outdoors and up to 30 m indoors (depending on the building materials)
- Power metering
- Overload and temperature protection
- Electrical power consumption < 1 W
- Microprocessor control
- Can connect to any Wi-Fi network or can operate as an Access Point
- Controlled via WiFi and a mobile phone, computer, automation system or any other device supporting HTTP and/or UDP protocol
