Wie kann ich ein kaputtes Script entfernen/deaktivieren?
    • Hilfreichste Antwort
    Hi
    gibt es:
    SetOption36Boot loop defaults restoration control.
    0 = disable boot loop control
    1..200 = set number of boot loops (a restart caused by any exception or watchdog timer within less than BOOT_LOOP_TIME (default 10 seconds) before beginning to restore settings (default = 1). Once this number is reached, subsequent restarts will:
    • 1st restart: disable ESP8285 generic GPIOs interfering with flash SPI
    • 2nd restart: disable rules causing boot loop
    • 3rd restart: disable all rules (and autoexec.bat)
    • 4th restart: reset user defined GPIOs to disable any attached peripherals
    • 5th restart: reset module to Sonoff Basic (1)
    benzino77 Tasmocompiler
    Gitpod Master Release
    mosquitto/bash/html/cgi auf RPI 2B+
  • Bumblebee
