Tasmota Rules: Der URL HTTP Aufruf als Trigger für ein CMD, geht das?
  • Hallo Zusammen,
    folgende Aufgabe möchte ich gern umsetzen und weiß nicht wirklich wie und ob es geht, vielleicht kann mir jemand helfen.
    Ich habe einen kleinen NoName WiFi IR Sender/Empfänger mit Tasmota geflasht um meinen Deckenventilator per IR Befehle zu steuern.
    Ich konnte die IR Befehle einlesen und jetzt auch ausgeben, um den Ventilator und das Licht zu steuern.
    Jedoch ist der Befehl sehr lang und als URL Aufruf zu lang um das direkt mit einem Shelly i3 zu steuern.
    Befehl / CMD:
    10:05:43.329 CMD: irsend 0,1270,430,1250,430,405,1270,410,1275,405,1275,405,1250,430,1275,405,1275,405,1275,405,1270,410,1270,405,7890,1275,430,1250,430,405,1270,410,1270,405,1275,1250,430,1250,430,1250,430,1250,430,1250,430,1250,430,1250,7075,1250,430,1250,435,405,1275,405,1270,410,1275,405,1275,405,1275,405,1270,1250,430,405,1275,405,1275,405,7890,1275,430,1250,430,405,1270,405,1275,405,1275,405,1275,405,1275,405,1275,1250,430,405,1270,405,1275,405,7895,1275,430,1245,430,410,1270,405,1270,405,1280,400,1270,405,1270,405,1270,1250,430,405,1275,405,1275,405,7920,1250,430,1250,430,405,1275,405,1275,405,1275,405,1275,405,1275,405,1275,1250,430,405,1275,405,1270,405,7890,1275,430,1250,430,405,1275,405,1275,405,1275,405,1275,405,1275,405,1275,1250,435,405,1275,405,1275,405
    HTTP Aufruf:
    http://192.168.178.109/cm?cmnd=irsend%200,1270,430,1250,430,405,1270,410,1275,405,1275,405,1250,430,1275,405,1275,405,1275,405,1270,410,1270,405,7890,1275,430,1250,430,405,1270,410,1270,405,1275,1250,430,1250,430,1250,430,1250,430,1250,430,1250,430,1250,7075,1250,430,1250,435,405,1275,405,1270,410,1275,405,1275,405,1275,405,1270,1250,430,405,1275,405,1275,405,7890,1275,430,1250,430,405,1270,405,1275,405,1275,405,1275,405,1275,405,1275,1250,430,405,1270,405,1275,405,7895,1275,430,1245,430,410,1270,405,1270,405,1280,400,1270,405,1270,405,1270,1250,430,405,1275,405,1275,405,7920,1250,430,1250,430,405,1275,405,1275,405,1275,405,1275,405,1275,405,1275,1250,430,405,1275,405,1270,405,7890,1275,430,1250,430,405,1275,405,1275,405,1275,405,1275,405,1275,405,1275,1250,435,405,1275,405,1275,405
    Jetzt würde ich gern eine URL bauen/setzen z.b: den HTTP Aufruf:
    http://192.168.178.109/cm?licht_an
    die dann als Trigger den Befehl (CMD): irsend ... aufruft.
    Hat jemand eine Idee wir ich das umsetzen könnte?
    Klar geht das auch als Script über den iobroker, da verwende ich die Steuerung über die VIS und es funktioniert tadellos.
    sollte der iobroker mal nicht erreichbar sein (warum auch immer) dann ginge es nicht, deshalb soll der Lichtschalter (Shelly i3) direkt senden.
    Hoffe meine Frage ist verständlich geschrieben.
    Danke Jui
  • Jui 21. Oktober 2021 um 21:29
    Hat den Titel des Themas von „Rules: Der URL HTTP Aufruf als Trigger für ein CMD, geht das?“ zu „Tasmota Rules: Der URL HTTP Aufruf als Trigger für ein CMD, geht das?“ geändert.
