Hallo, hat es jemand geschafft den https://templates.blakadder.com/lenovo_ZG38C02927.html in Funktion zu setzen? Ich habe ihn gemäß der Anleitung mit tasmota-battery.bin geflashed und die Einstellungen entsprechend vorgenommen, er läuft aber in einer Boot-Schleife (s. unten, danach startet er neu). Hat jemand eine Idee, was da falsch läuft?
- Joachim.
00:00:00 CFG: Loaded from flash at F5, Count 97
00:00:00 CFG: CR 335/699, Busy 0
00:00:00 SNS: Hardware Serial
00:00:00 TYA: Request MCU configuration at 9600 bps
00:00:00 TYA: Send "55aa0001000000"
00:00:00 SRC: Restart
00:00:00 TYA: Send "55aa0006000501010001010e"
00:00:00 Project tasmota Tasmota Version 8.5.0.1(battery)-2_7_4_1
00:00:00 TYA: Set WiFi LED 2 (-1)
00:00:00 TYA: Send "55aa000200010204"
00:00:00 WIF: Checking connection...
00:00:00 WIF: Attempting connection...
00:00:00 WIF: Connecting to AP1 Rennweg-IoT Channel 1 BSSId 6E:3B:6B:19:74:92 in mode 11N as PIR-4022...
00:00:01 WIF: Checking connection...
00:00:01 WIF: Connected
19:01:47 NTP: UTC 2020-10-01T18:01:46, DST 2020-03-29T02:00:00, STD 2020-10-25T03:00:00
19:01:47 HTP: Web server active on PIR-4022 with IP address 10.21.250.23
19:01:47 HTP: Main Menu
19:01:47 TYA: Set WiFi LED 3 (0)
19:01:47 TYA: Send "55aa000200010305"
19:01:47 RSL: PIR/RESULT = {"TuyaReceived":{"Data":"55AA0002000001","Cmnd":2}}
19:01:48 MQT: Attempting connection...
19:01:48 MQT: Connected
19:01:48 MQT: PIR/LWT = Online (retained)
19:01:48 MQT: Subscribe to PIR/cmnd/#
19:01:48 MQT: Unsubscribe from homeassistant/status
19:01:48 MQT: PIR/INFO1 = {"Module":"Lenovo PIR","Version":"8.5.0.1(battery)","FallbackTopic":"cmnd/PIR_fb/","GroupTopic":"PIR/cmnd/"}
19:01:48 MQT: PIR/INFO2 = {"WebServerMode":"Admin","Hostname":"PIR-4022","IPAddress":"10.21.250.23"}
19:01:48 MQT: PIR/INFO3 = {"RestartReason":"Power On"}
19:01:48 MQT: PIR/RESULT = {"POWER":"ON"}
19:01:48 MQT: tasmota/discovery/483FDA62AFB6/config = {"ip":"10.21.250.23","dn":"Tasmota","fn":["Tasmota",null,null,null,null,null,null,null],"hn":"PIR-4022","mac":"483FDA62AFB6","md":"Lenovo PIR","ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"8.5.0.1","t":"PIR","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"btn":[0,0,0,0],"so":{"11":0,"13":0,"17":0,"20":0,"30":0,"37":1,"68":0,"73":0,"80":0},"lt_st":0,"ver":1} (retained)
19:01:48 MQT: tasmota/discovery/483FDA62AFB6/sensors = {{"Time":"2020-10-01T19:01:48"},"ver":1} (retained)
19:01:48 TYA: Set WiFi LED 4 (0)
19:01:48 TYA: Send "55aa000200010406"
19:01:48 MQT: PIR/RESULT = {"TuyaReceived":{"Data":"55AA0002000001","Cmnd":2}}
19:01:49 HTP: Console
19:01:52 MQT: PIR/STATE = {"Time":"2020-10-01T19:01:52","Uptime":"0T00:00:09","UptimeSec":9,"Heap":30,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Rennweg-IoT","BSSId":"6E:3B:6B:19:74:92","Channel":1,"RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:03"}}
19:01:53 APP: Boot Count 75
19:01:53 CFG: Saved to flash at F4, Count 98, Bytes 4096
