Beiträge von Dirdan
    Entschuldigen Sie die die späte Rückmeldung.
    Haben Sie vielleicht ein Messinstrument ?? Ich habe das zwar angeschlossen, aber vorher die Polarität mit einem Instrument ausgemessen. Der Plus sollte stimmen. Beachten Sie auch die gelben Ringe.Anmerkung: Ich denke aber der Kontakt zum Magnet wird mit der Orignal Software nicht gehen. Viel Erfolg.
    Thanks for your attention!
    I verified the polarity on 9 connector with a tester, and it's confirm that the negative is on RT-
    I tested also the polarity between +24V connector and 9 connector with the same result.
    Pratically i connect the shelly 1.3 as below:
    Regarding the magnetic connector, it's wired on SW and L, as by your scheme. Really the shelly app don't permit to see the door image open and close, but there the possibility to see the input status with green for close and red for open.
    Diffently with HomeAssistant, that with a cover can manage the differents status with the images without problem.
    Now my doubt is, if the my board is different from your or my conclusion are wrong, and it's possible to connect the Shelly L- on GN+ and RT- without problems.
    Thanks in advance for your possible clarification.
    Hello eveyone and many thanks Jurgen for project sharing. I would like to use a shelly 1 with original firmware on a same Sommer unit, but looking your scheme it's not clear for me if the - Polarity Shelly is attached to GN+ or must be on rt+ of the connector 11 Sommer board
    Thanks in advance for your contribution.
