Beiträge von asco
    Danke für die Hilfe. Das mit der Temperatur kannst Du gerne ändern.
    Hier der Export.
    Also hab ich vergessen, der Temperatursensor ist an einem andern Sonoff,
    <xml xmlns="https://developers.google.com/blockly/xml">
    <block type="on" id="X}1-yRbqU795F47q,aE5" x="67" y="81">
    <field name="OID">sonoff.0.Reserve.DS18B20_Temperature</field>
    <field name="CONDITION">any</field>
    <field name="ACK_CONDITION"></field>
    <statement name="STATEMENT">
    <block type="controls_if" id="j0E~Kt.UtWV(dVF5B;Nv">
    <mutation elseif="1"></mutation>
    <value name="IF0">
    <block type="logic_operation" id="C0i*-}Dk2+7JY{@Q{--%" inline="false">
    <field name="OP">AND</field>
    <value name="A">
    <block type="logic_compare" id="0~*+a?SQyy5v/v;GoFqB">
    <field name="OP">LTE</field>
    <value name="A">
    <block type="on_source" id=",YgzG7*2gQOo@3?6Qc(R">
    <field name="ATTR">state.val</field>
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="UL-$W@*W^xNFQmUOm8|_">
    <field name="NUM">15</field>
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="logic_negate" id=",wuw`2#B{t.uQT@b:l@)">
    <value name="BOOL">
    <block type="get_value" id="0iNN642bsN?)x0Un,V3H">
    <field name="ATTR">val</field>
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="control" id="z=SHAD_,Us$,VE6k?Gi$">
    <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation>
    <field name="OID">sonoff.0.Heizung.POWER</field>
    <field name="WITH_DELAY">FALSE</field>
    <value name="VALUE">
    <block type="logic_boolean" id="q*;OmD,R@Yq!:{ip:}|^">
    <field name="BOOL">TRUE</field>
    </block>
    </value>
    </block>
    </statement>
    <value name="IF1">
    <block type="logic_operation" id="O~R~IY~TexN8nVGxZw;d" inline="false">
    <value name="A">
    <block type="logic_compare" id="a$6qnh@{z;Q8yY$kYser">
    <field name="OP">GT</field>
    <value name="A">
    <block type="on_source" id="wC#FXMSKT/=vrIwOZa9t">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="YF;9oV$P%N|dFhv%#g!9">
    <field name="NUM">20</field>
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="get_value" id="uK81OG^$(TTZ2{Z?F`C@">
    </block>
    </value>
    </block>
    </value>
    <statement name="DO1">
    <block type="control" id="(~E4m3AIvz$68uEBM_jv">
    <block type="logic_boolean" id="NL7t5*a}ylxxns*,eY3k">
    <field name="BOOL">FALSE</field>
    </block>
    </value>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </xml>
    Hallo zusammen.
    Ich habe noch ein Problem.
    Möchte ich z.B. eine Lampe ( am Shelly1 oder sonoff basic ) mit Alexa einschalten kommt der Spruch: Lampe antwortet nicht, bitte überprüfe die Netzwerkverbindung oder Stromversorgung des Geräts. Aber sofort nachdem 2. mal geht das Licht an.
    Alles was an der Philips Bridge, und der Sonoff Bridge WLAN zu 433 Mhz funktioniert sofort. Nur was an den Sonoff Basics oder Shellys hängt muss ich 2 mal ansprechechen, des es schaltet.
    Viele Sachen habe ich schon probiert: Amazon Echo Werkseinstellung, Fritz Box Werkseinstellung, Shelly oder Sonoff neu geflasht ( sogar Softwarestände geändert ).
    Bin am verzweifeln. Was läuft falsch?
    Steffen
    Hallo zusammen.
    Ich hatte in den letzten Tagen Probleme mit Alexa. Es kam immer: überprüfen sie ihre Netzwerkverbindung und Stromversorgung. Nach der zweiten Ansage hat Alexa dann geschaltet. Bin auf Ursachenforschung gegangen und habe ein Ergebnis gefunden. Vor einigen Tagen hatte ich in der Fritz Box die Verschlüsselung auf WPA3 geändert.
    Heute habe ich die Verschlüsselung wieder auf WPA / Wpa2 zurück geändert.
    Von Alexa kommen keine Sprüche mehr, alles funktioniert wieder.
    Vielleicht hilft das vielen weiter, die Probleme haben.
    Eine Frage habe ich aber, wer kommt mit WPA 3 nicht klar. Die Sonoffs, die Shellys, Alexa oder alle?
    Liebe Grüße
    Steffen
    Hallo Marc.
    Mit dem Drucker das bekomme ich nicht hin. Ich habe einen Brother HL 2030 lokal am USB Port des Raspi angeschlossen. In CUPS ist er auch eingerichtet. Kann vom Mac, vom Ipad von W10 darauf drucken. wenn ich den s
    Startbefehl aus deiner Config in den Browser eingebe kann ich auch drucken. Wenn ich aber die Datei /etc/systemd/system/abcdefg.service speichere und drucken möchte passiert nichts. Wo ist mein Fehler?
    Im Vorraus danke für die Hilfe.
    Steffen
    Hallo.
    Ich habe ein Problem mit 2 Sonoff basic.
    Prinzipiell funktionieren beide,
    Habe eine 7490 und eine 7240 zusammen in betrieb.
    Schalte ich die 7240 ab gehen beide Sonoff nicht mehr, schalte ich den Repeater wieder ein
    funktionieren beide Sonoff wieder.
    Das heißt an der 7490 zicken beide.
    Firmware der Sonoff ist: 6.3.0
    Die Fritz Boxen sind auch aktuell.
    Wo kann mein Fehler sein?
    Steffen
    Hallo.
    ich möchte Euch nur zeigen wie ich jetzt meine Sonoff basic und meine Sonoff Bridge
    die mit der Espurna Software geflasht sind direkt über den Browser schalten kann.
    Gebt in der Adresszeile deines Browsers (nach Anpassung Eurer IP und des API-Keys )
    ein:
    Einschalten:
    http://192.168.2.140/api/relay/0?apikey ... 93&value=1
    Ausschalten:
    http://192.168.2.140/api/relay/0?apikey ... 93&value=0
    Den API-Key findest Ihr in ESPURNA unter Admin.
    Wenn das Relais dann nicht schaltet, ist irgendwas verkehrt eingestellt.
    Den Tipp habe ich aus dem Netz, ist getestet und funktionirt 100%.
    Diese Behle funktionieren auch in VIS vom Iobroker.
    1. Reihe Sonoff Touch, Sonoff Basic, Sonoff POW mit Tasmota Software.
    2. Reihe Sonoff Basic mit Espurna Software.
    3. Reihe Sonoff Bridge mit Espurna womit 433Mhz Steckdosen geschaltet werden.
    Steffen
