erase flash geht bei mir nicht, und die neue Datei drauf flashen auch nicht hast du noch einen Tip?
i@raspberrypi:~ $ esptool.py --port /dev/ttyAMA0 erase_flash
esptool.py v2.5.0
Serial port /dev/ttyAMA0
Connecting...
Traceback (most recent call last):
File "/usr/local/bin/esptool.py", line 2849, in <module>
_main()
File "/usr/local/bin/esptool.py", line 2842, in _main
main()
File "/usr/local/bin/esptool.py", line 2543, in main
esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
File "/usr/local/bin/esptool.py", line 245, in detect_chip
detect_port.connect(connect_mode)
File "/usr/local/bin/esptool.py", line 444, in connect
last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
File "/usr/local/bin/esptool.py", line 424, in _connect_attempt
self.sync()
File "/usr/local/bin/esptool.py", line 363, in sync
timeout=SYNC_TIMEOUT)
File "/usr/local/bin/esptool.py", line 306, in command
self.write(pkt)
File "/usr/local/bin/esptool.py", line 269, in write
self._port.write(buf)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 538, in write
raise writeTimeoutError
serial.serialutil.SerialTimeoutException: Write timeout
Alles anzeigen
