Hab das ganze auf 60 sekunden reduziert. Schaltet aber auch nicht ab. Version Tasmota 10.0.0.4
11:14:44.748 CMD: rule1 5
11:14:44.755 MQT: stat/tasmotatemp/RESULT = {"Rule1":{"State":"ON","Once":"ON","StopOnError":"OFF","Length":119,"Free":392,"Rules":"on AM2301#HUMIDITY>60 do power2 1 endon on AM2301#HUMIDITY<55 do ruletimer1 60 endon on rules#timer=1 do power2 0 endon"}}
11:14:45.043 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
11:14:45.051 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
11:14:49.821 CMD: rule1 1
11:14:49.828 MQT: stat/tasmotatemp/RESULT = {"Rule1":{"State":"ON","Once":"ON","StopOnError":"OFF","Length":119,"Free":392,"Rules":"on AM2301#HUMIDITY>60 do power2 1 endon on AM2301#HUMIDITY<55 do ruletimer1 60 endon on rules#timer=1 do power2 0 endon"}}
11:14:50.017 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
11:14:50.025 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
11:15:06.870 CMD: rule1 on AM2301#HUMIDITY>60 do power2 1 endon on AM2301#HUMIDITY<55 do ruletimer1 60 endon on rules#timer=1 do power2 0 endon
11:15:06.877 RUL: Stored uncompressed, would compress from 119 to 71 (-40%)
11:15:06.882 MQT: stat/tasmotatemp/RESULT = {"Rule1":{"State":"ON","Once":"ON","StopOnError":"OFF","Length":119,"Free":392,"Rules":"on AM2301#HUMIDITY>60 do power2 1 endon on AM2301#HUMIDITY<55 do ruletimer1 60 endon on rules#timer=1 do power2 0 endon"}}
11:15:07.171 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
11:15:07.179 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
11:15:24.746 MQT: stat/tasmotatemp/RESULT = {"POWER2":"ON"}
11:15:24.748 MQT: stat/tasmotatemp/POWER2 = ON
11:16:07.401 RUL: RULES#TIMER=1 performs "power2 0"
11:16:07.408 MQT: stat/tasmotatemp/RESULT = {"POWER2":"OFF"}
11:16:07.410 MQT: stat/tasmotatemp/POWER2 = OFF
11:16:39.408 MQT: tele/tasmotatemp/STATE = {"Time":"2021-12-24T11:16:39","Uptime":"0T23:10:08","UptimeSec":83408,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Interwebs","BSSId":"5C:49:79:48:D0:DD","Channel":1,"Mode":"11n","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:16:39.418 MQT: tele/tasmotatemp/SENSOR = {"Time":"2021-12-24T11:16:39","Switch1":"ON","Switch2":"ON","Switch3":"ON","AM2301":{"Temperature":16.7,"Humidity":51.2,"DewPoint":6.5},"TempUnit":"C"}
11:18:21.066 MQT: stat/tasmotatemp/RESULT = {"POWER2":"ON"}
11:18:21.069 MQT: stat/tasmotatemp/POWER2 = ON
11:18:21.226 MQT: stat/tasmotatemp/RESULT = {"POWER1":"ON"}
11:18:21.229 MQT: stat/tasmotatemp/POWER1 = ON
11:18:21.627 MQT: stat/tasmotatemp/RESULT = {"POWER1":"OFF"}
11:18:21.632 MQT: stat/tasmotatemp/POWER1 = OFF
Alles anzeigen
Wenn ich alles neu eingabe schaltet er beim Ersten mal ab danach nicht mehr.
12:11:56.630 RUL: AM2301#HUMIDITY>60 performs "power2 1"
12:11:56.636 MQT: stat/tasmotatemp/RESULT = {"POWER2":"ON"}
12:11:56.639 MQT: stat/tasmotatemp/POWER2 = ON
12:12:34.443 MQT: tele/tasmotatemp/STATE = {"Time":"2021-12-24T12:12:34","Uptime":"0T00:30:09","UptimeSec":1809,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Interwebs","BSSId":"5C:49:79:48:D0:DD","Channel":1,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:12:34.454 MQT: tele/tasmotatemp/SENSOR = {"Time":"2021-12-24T12:12:34","Switch1":"ON","Switch2":"ON","Switch3":"ON","AM2301":{"Temperature":16.9,"Humidity":71.7,"DewPoint":11.7},"TempUnit":"C"}
12:13:38.874 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
12:13:38.883 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:15:37.885 CMD: timer1
12:15:37.893 MQT: stat/tasmotatemp/RESULT = {"Timer1":{"Enable":0,"Mode":0,"Time":"00:00","Window":0,"Days":"0000000","Repeat":0,"Output":1,"Action":0}}
2er Vesuch mit Rücksetzen des Timer bei >60 . Leider das gleich ergebnis. Einmal stoppt er danach nicht mehr
rule1 on AM2301#HUMIDITY>60 do backlog power2 1; ruletimer1 0 endon
12:19:13.876 MQT: stat/tasmotatemp/RESULT = {"Rule1":{"State":"ON","Once":"ON","StopOnError":"OFF","Length":141,"Free":370,"Rules":"on AM2301#HUMIDITY>60 do backlog power2 1; ruletimer1 0 endon on AM2301#HUMIDITY<55 do ruletimer1 60 endon on rules#timer=1 do power2 0 endon"}}
12:19:14.069 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
12:19:14.077 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:19:40.555 RUL: AM2301#HUMIDITY>60 performs "backlog power2 1; ruletimer1 0"
12:19:40.597 MQT: stat/tasmotatemp/RESULT = {"POWER2":"ON"}
12:19:40.600 MQT: stat/tasmotatemp/POWER2 = ON
12:19:40.820 MQT: stat/tasmotatemp/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:20:44.827 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
12:20:44.835 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:21:45.447 RUL: RULES#TIMER=1 performs "power2 0"
12:21:45.454 MQT: stat/tasmotatemp/RESULT = {"POWER2":"OFF"}
12:21:45.457 MQT: stat/tasmotatemp/POWER2 = OFF
12:22:06.644 RUL: AM2301#HUMIDITY>60 performs "backlog power2 1; ruletimer1 0"
12:22:06.686 MQT: stat/tasmotatemp/RESULT = {"POWER2":"ON"}
12:22:06.689 MQT: stat/tasmotatemp/POWER2 = ON
12:22:06.888 MQT: stat/tasmotatemp/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:22:34.468 MQT: tele/tasmotatemp/STATE = {"Time":"2021-12-24T12:22:34","Uptime":"0T00:40:09","UptimeSec":2409,"Heap":10,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Interwebs","BSSId":"5C:49:79:48:D0:DD","Channel":1,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:22:34.479 MQT: tele/tasmotatemp/SENSOR = {"Time":"2021-12-24T12:22:34","Switch1":"ON","Switch2":"ON","Switch3":"ON","AM2301":{"Temperature":17.0,"Humidity":65.0,"DewPoint":10.4},"TempUnit":"C"}
12:23:22.851 RUL: AM2301#HUMIDITY<55 performs "ruletimer1 60"
12:23:22.860 MQT: stat/tasmotatemp/RESULT = {"T1":60,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
12:27:18.246 CMD: timer1
12:27:18.254 MQT: stat/tasmotatemp/RESULT = {"Timer1":{"Enable":0,"Mode":0,"Time":"00:00","Window":0,"Days":"0000000","Repeat":0,"Output":1,"Action":0}}
12:27:34.453 MQT: tele/tasmotatemp/STATE = {"Time":"2021-12-24T12:27:34","Uptime":"0T00:45:09","UptimeSec":2709,"Heap":11,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Interwebs","BSSId":"5C:49:79:48:D0:DD","Channel":1,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:27:34.463 MQT: tele/tasmotatemp/SENSOR = {"Time":"2021-12-24T12:27:34","Switch1":"ON","Switch2":"ON","Switch3":"ON","AM2301":{"Temperature":17.0,"Humidity":50.9,"DewPoint":6.7},"TempUnit":"C"}
Alles anzeigen
