16:24:18 CMD: Weblog 3 1
16:24:18 RSL: stat/tasmota_CBCB8B/RESULT = {"WebLog":3}
16:24:18 CFG: in Flash gespeichert am F9, zählen 22, Bytes 4096
16:24:24 HTP: Hauptmenü
16:24:26 SRC: WebGui from 192.168.10.72
16:24:26 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER1":"OFF"}
16:24:26 RSL: stat/tasmota_CBCB8B/POWER1 = OFF
16:24:26 CFG: in Flash gespeichert am F8, zählen 23, Bytes 4096
16:24:27 SRC: WebGui from 192.168.10.72
16:24:27 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER2":"OFF"}
16:24:27 RSL: stat/tasmota_CBCB8B/POWER2 = OFF
16:24:27 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER1":"ON"}
16:24:27 RSL: stat/tasmota_CBCB8B/POWER1 = ON
16:24:27 CFG: in Flash gespeichert am F7, zählen 24, Bytes 4096
16:24:28 SRC: WebGui from 192.168.10.72
16:24:28 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER2":"ON"}
16:24:28 RSL: stat/tasmota_CBCB8B/POWER2 = ON
16:24:28 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER1":"OFF"}
16:24:28 RSL: stat/tasmota_CBCB8B/POWER1 = OFF
16:24:28 CFG: in Flash gespeichert am F6, zählen 25, Bytes 4096
16:24:29 SRC: WebGui from 192.168.10.72
16:24:29 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER2":"OFF"}
16:24:29 RSL: stat/tasmota_CBCB8B/POWER2 = OFF
16:24:29 RSL: stat/tasmota_CBCB8B/RESULT = {"POWER1":"ON"}
16:24:29 RSL: stat/tasmota_CBCB8B/POWER1 = ON
16:24:29 CFG: in Flash gespeichert am F5, zählen 26, Bytes 4096
16:24:30 HTP: Konsole
Alles anzeigen
Das wäre der Output, wenn ich die Schalter im Web-If benutze.
Bezüglich Downgrade. Wenn ich die Url der Tamota-Mini eintrage, kann ich zwar dann die Tasmota7.bin auswählen, es kommt dann jedoch der Fehler "not compatible".
16:09:41 CMD: Rule1 ON Button1#State=2 DO Power1 2 ENDON
16:09:41 SRC: WebConsole from 192.168.10.72
16:09:41 CMD: Group 0, Index 1, Command "RULE", Data "ON Button1#State=2 DO Power1 2 ENDON"
16:09:41 RUL: Stored uncompressed, would compress from 36 to 34 (-6%)
16:09:41 RSL: stat/tasmota/RESULT = {"Rule1":"ON","Once":"OFF","StopOnError":"OFF","Length":36,"Free":475,"Rules":"ON Button1#State=2 DO Power1 2 ENDON"}
16:09:41 CFG: Saved to flash at F7, Count 492, Bytes 4096
16:09:55 CMD: Rule1 1
16:09:55 SRC: WebConsole from 192.168.10.72
16:09:55 CMD: Group 0, Index 1, Command "RULE", Data "1"
16:09:55 RSL: stat/tasmota/RESULT = {"Rule1":"ON","Once":"OFF","StopOnError":"OFF","Length":36,"Free":475,"Rules":"ON Button1#State=2 DO Power1 2 ENDON"}
Leider zeigt der Button auf der Steckdose keine Reaktion im Log
Habe die Befehle aus dem Post #7 und das Template aus #8 eingetragen. Keine Veränderung. Die Taste ist ohne Funktion. Sie leuchtet aber nun Blau im eingeschaltetem Zustand.
