Beiträge von riker1
    Ich habe mal die Tasmota32-webcam.bin (8.5.0) aufgespielt. Bild ist besser als erwartet. Hat das noch jemand am laufen und macht auch Kamera Auswertungen ?
    (Bewegungserkennung, Gesichtserkennung o.ä.)
    Hallo, ich wollte das auch probieren, bekomme aber immer fehler beim flashen bzw der upload via OTA bricht ab. Flash error size. Wie hast du den ESP32 konfiguriert? Danke für die Hife VG T
    Hi Jörg,
    ok thanks.
    I expected the ssid as AP : tasmota-4082
    but no AP was showing up
    That is what confused me.
    I managed now to get a wifi connection working via serial and got a hint in an issue
    that probably due to old firmware and sdk on the ESP the config was messed up.
    Looks like I have to delete old settings. But I am looking for an OTA way to migrate the ESPs from ESP-Easy to tasmota without serial connection...
    Thanks Thomas
    Hi
    I flashed Tasmota on a witty via OTA .
    Witty was formerly running ESPEasy firmware.
    AP is not coming up. Do not see the SSID.
    Tasmota Version 8.1.0.2(tasmota)-2_6_1
    web server active on tasmota-4082 with IP address (IP unset)
    Did I miss anything?
    see serial log with Status 0
    After running status 0 the witty restarted.
    Thanks Thomas
    07:20:43.943 -> 00:00:00 CFG: Loaded from flash at F6, Count 6 07:20:43.943 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:20:44.109 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:20:44.607 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:23:46.374 -> 00:03:02 APP: Restarting 07:23:46.473 -> 07:23:46.473 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:23:46.473 -> 07:23:46.507 -> load 0x4010f000, len 1384, room 16 07:23:46.507 -> tail 8 07:23:46.507 -> chksum 0x2d 07:23:46.507 -> csum 0x2d 07:23:46.507 -> v482516e3 07:23:46.507 -> ~ld 07:23:46.639 -> 00:00:00 CFG: Loaded from flash at F5, Count 7 07:23:46.639 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:23:46.772 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:23:47.304 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:26:49.077 -> 00:03:02 APP: Restarting 07:26:49.176 -> 07:26:49.176 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:26:49.176 -> 07:26:49.209 -> load 0x4010f000, len 1384, room 16 07:26:49.209 -> tail 8 07:26:49.209 -> chksum 0x2d 07:26:49.209 -> csum 0x2d 07:26:49.209 -> v482516e3 07:26:49.209 -> ~ld 07:26:49.308 -> 00:00:00 CFG: Loaded from flash at F4, Count 8 07:26:49.342 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:26:49.474 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:26:49.974 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:29:51.779 -> 00:03:02 APP: Restarting 07:29:51.856 -> 07:29:51.856 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:29:51.856 -> 07:29:51.935 -> load 0x4010f000, len 1384, room 16 07:29:51.935 -> tail 8 07:29:51.935 -> chksum 0x2d 07:29:51.935 -> csum 0x2d 07:29:51.935 -> v482516e3 07:29:51.935 -> ~ld 07:29:52.014 -> 00:00:00 CFG: Loaded from flash at FB, Count 9 07:29:52.014 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:29:52.179 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:29:52.681 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:32:45.141 -> 00:02:53 CMD: status 0 07:32:45.141 -> 00:02:53 RSL: stat/tasmota/STATUS = {"Status":{"Module":18,"FriendlyName":["Tasmota"],"Topic":"tasmota","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}} 07:32:45.174 -> 00:02:53 RSL: stat/tasmota/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:02:54","StartupUTC":"","Sleep":50,"CfgHolder":4617,"BootCount":8,"SaveCount":10,"SaveAddress":"FA000"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS2 = {"StatusFWR":{"Version":"8.1.0.2(tasmota)","BuildDateTime":"2019-12-30T19:07:34","Boot":17,"Core":"2_6_1","SDK":"2.2.2-dev(38a443e)","Hardware":"ESP8266EX","CR":"287/699"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00000000"]}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS4 = {"StatusMEM":{"ProgramSize":452,"Free":548,"Heap":34,"ProgramFlashSize":1024,"FlashSize":4096,"FlashChipId":"1640EF","FlashMode":3,"Features":["00000809","0F400082","04048000","00000005","000000C0","00000080"],"Drivers":"1,2,3,4,9,10,12,16","Sensors":"1,2,3"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS5 = {"StatusNET":{"Hostname":"tasmota-4082","IPAddress":"(IP unset)","Gateway":"192.168.1.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.1.1","Mac":"4C:11:AE:0E:8F:F2","Webserver":2,"WifiConfig":2,"WifiPower":17.0}} 07:32:45.311 -> 00:02:53 RSL: stat/tasmota/STATUS6 = {"StatusMQT":{"MqttHost":"","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_0E8FF2","MqttUser":"DVES_USER","MqttCount":0,"MAX_PACKET_SIZE":1000,"KEEPALIVE":30}} 07:32:45.311 -> 00:02:53 RSL: stat/tasmota/STATUS7 = {"StatusTIM":{"UTC":"Thu Jan 01 00:02:53 1970","Local":"Thu Jan 01 00:02:53 1970","StartDST":"Thu Jan 01 00:00:00 1970","EndDST":"Thu Jan 01 00:00:00 1970","Timezone":"+00:00","Sunrise":"07:43","Sunset":"16:03"}} 07:32:45.342 -> 00:02:53 RSL: stat/tasmota/STATUS10 = {"StatusSNS":{"Time":"1970-01-01T00:02:53"}} 07:32:45.342 -> 00:02:53 RSL: stat/tasmota/STATUS11 = {"StatusSTS":{"Time":"1970-01-01T00:02:53","Uptime":"0T00:02:54","UptimeSec":174,"Heap":34,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"","BSSId":"B1:C8:A1:D8:91:E8","Channel":1,"RSSI":100,"Signal":31,"LinkCount":0,"Downtime":"0T00:00:00"}}} 07:32:54.686 -> 00:03:02 APP: Restarting 07:32:54.786 -> 07:32:54.786 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:32:54.786 -> 07:32:54.842 -> load 0x4010f000, len 1384, room 16 07:32:54.842 -> tail 8 07:32:54.842 -> chksum 0x2d 07:32:54.842 -> csum 0x2d 07:32:54.842 -> v482516e3 07:32:54.842 -> ~ld 07:32:54.952 -> 00:00:00 CFG: Loaded from flash at FA, Count 10 07:32:54.952 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:32:55.118 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:32:55.617 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset)
