Beiträge von Heidelbeerkoenig
    Hallo, bin ein Neuling und habe das Problem mit dem Sensor, der an zwei THxx immer den Wert null zeigt. Habe schon alles beschriebene probiert. Sensorstecker! usw. Kann mir geholfen werden?
    Hier ein Auszug aus der Konsole:
    09:46:51.223 RSL: STATE = {"Time":"2024-09-24T09:46:51","Uptime":"0T00:00:10","UptimeSec":10,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":88,"Signal":-56,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:46:51.244 RSL: SENSOR = {"Time":"2024-09-24T09:46:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
    09:51:51.226 RSL: STATE = {"Time":"2024-09-24T09:51:51","Uptime":"0T00:05:10","UptimeSec":310,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":88,"Signal":-56,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:51:51.248 RSL: SENSOR = {"Time":"2024-09-24T09:51:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
    09:56:41.214 APP: Serielles Logging deaktiviert
    09:56:51.208 RSL: STATE = {"Time":"2024-09-24T09:56:51","Uptime":"0T00:10:10","UptimeSec":610,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:56:51.212 RSL: SENSOR = {"Time":"2024-09-24T09:56:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
    18:59:18 RSL: tele/sonoff/STATE = {"Time":"2019-12-15T18:59:18","Uptime":"0T03:14:59","UptimeSec":11699,"Heap":28,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":2,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:05"}}
    19:04:18 RSL: tele/sonoff/STATE = {"Time":"2019-12-15T19:04:18","Uptime":"0T03:19:59","UptimeSec":11999,"Heap":28,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":2,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:05"}}
    19:08:32 CMD: setoption63
    19:08:32 RSL: stat/sonoff/RESULT = {"SetOption63":"OFF"}
    19:09:18 RSL: tele/sonoff/STATE = {"Time":"2019-12-15T19:09:18","Uptime":"0T03:24:59","UptimeSec":12299,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":2,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Hallo Gemeinde,
    danke für die große Unterstützung. Jetzt funktioniert einer der beiden Sonoffs CH4 Pro. Ohne euch hätte es nicht geklappt. Dankeschön!
    Mit dem Zweiten habe ich ein Problem, dass ich nicht auf das WLAN komme. Ich hatte mit WiFi Befehlen experimentiert und komme nicht mehr an das Gerät. Es wir kein Netzwerkzugang angezeigt.
    Das Rücksetzen mit der Drahtbrücke Ground auf GIOOP über 40 Sekunden hat auch nicht geklappt. Wie bekomme ich das Teil wieder in den Zustand, dass es mir die Sonoff-Adresse bzw. den Zugang über 192.168.4.1 ermöglicht.
    Danke für die Unterstützung im Voraus.
    Hallo Gemeinde,
    Hallo Jörg,
    vielen Danke für die freundliche Hilfsbereitschaft. Da ich mir keinen Rat mehr wusste und mit den Vorschlägen auch nicht mehr weiter gekommen bin habe ich die Schalter jetzt noch einmal mit Firmware 6.7.1 geflasht. Nach der Eingabe der vorstehenden Befehle ist es so, dass bei einem Warm- oder Kaltstart nicht mehr getastet wird. Das ist schon einmal sehr gut.
    Allerdings verliert der Schalter jetzt das WLAN, wenn der Router eine neue IP liefert und startet die Seite 192.168.4.1. Das ist auch nicht schön. Gibt es eine Möglichkeit dem Schalter die SSDI und das Passwort fest mitzugeben?
    Weiterhin ist mir aufgefallen, dass bei einem Warmstart der Taster z.B. Relais 1 betätigt wird, wenn vorher auf dem Schalter hardwarmäßig das entsprechende Relais geschaltet wurde. Ist für mich nicht problematisch, das eine manuelle Schaltung der Relais am CH4 nicht vorkommen wird. Trotzdem ist das Verhalten schon sehr speziell-
    Jörg wollte noch folgendes wissen:
    savedata:
    poweronstate
    rule 1-3
    interlock
    setoption0
    setoption63
    00:00:00 CFG: aus Flash geladen am FB, zählen 65
    00:00:00 Projekt sonoff Sauna Licht Version 6.7.1(sonoff)-STAGE
    00:00:00 WIF: verbinden mit AP1 SSR in Modus 11N als sonoff-0747...
    00:00:04 WIF: verbunden
    00:00:04 HTP: Web-Server aktiv bei sonoff-0747 mit IP-Adresse 192.168.178.102
    19:33:08 RSL: tele/sonoff/STATE = {"Time":"2019-12-13T19:33:08","Uptime":"0T00:04:59","UptimeSec":299,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":74,"LinkCount":1,"Downtime":"0T00:00:05"}}
    19:38:08 RSL: tele/sonoff/STATE = {"Time":"2019-12-13T19:38:08","Uptime":"0T00:09:59","UptimeSec":599,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":72,"LinkCount":1,"Downtime":"0T00:00:05"}}
    19:38:09 APP: Serielles Logging deaktiviert
    19:41:38 CMD: savedata
    19:41:38 RSL: stat/sonoff/RESULT = {"SaveData":"ON"}
    19:42:08 CMD: poweronstate
    19:42:08 RSL: stat/sonoff/RESULT = {"PowerOnState":0}
    19:42:46 CMD: rule1
    19:42:46 RSL: stat/sonoff/RESULT = {"Rule1":"ON","Once":"OFF","StopOnError":"OFF","Free":439,"Rules":"on system#boot do backlog power1 0; power3 0; power2 0; power4 0; endon"}
    19:42:54 CMD: rule2
    19:42:54 RSL: stat/sonoff/RESULT = {"Rule2":"ON","Once":"OFF","StopOnError":"OFF","Free":417,"Rules":"on event#neustart do backlog power1 0; power2 0; power3 0; power4 0; delay 2; restart 1; endon"}
    19:43:04 CMD: rule3
    19:43:04 RSL: stat/sonoff/RESULT = {"Rule3":"OFF","Once":"OFF","StopOnError":"OFF","Free":511,"Rules":""}
    19:43:08 RSL: tele/sonoff/STATE = {"Time":"2019-12-13T19:43:08","Uptime":"0T00:14:59","UptimeSec":899,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":74,"LinkCount":1,"Downtime":"0T00:00:05"}}
    19:43:48 CMD: interlock
    19:43:48 RSL: stat/sonoff/RESULT = {"Interlock":"OFF","Groups":"1,2,3,4"}
    19:44:41 CMD: setoption0
    19:44:41 RSL: stat/sonoff/RESULT = {"SetOption0":"ON"}
    19:44:57 CMD: setoptio63
    19:44:57 RSL: stat/sonoff/RESULT = {"Command":"Unknown"}
    Hallo Jörg, ich habe alle Vorschläge umgesetzt, nur neu Flashed konnte ich nicht, da mir die notwendigen Teile fehlen. Die Rule habe ich eingetragen.
    Nachfolgend das Ergebnis aus der Konsole nach dem Befehl event neustart
    Der Taster Power 4 schaltet wie gehabt in der vierten Zeile sofort nach dem Neustart. Aber es hat sich etwas verändert. Sie weiter unten nach Stromlos schaltet das Relais nicht mehr.
    00:00:00 CFG: aus Flash geladen am FB, zählen 491
    00:00:00 Projekt sonoff Sauna Version 6.7.1(sonoff)-STAGE
    00:00:03 RSL: RESULT = {"POWER4":"ON"}
    00:00:03 RSL: POWER4 = ON
    19:57:09 RSL: INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.7.1(sonoff)","FallbackTopic":"cmnd/DVES_CE02EB_fb/","GroupTopic":"sonoffs"}
    19:57:09 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-0747","IPAddress":"192.168.178.102"}
    19:57:09 RSL: INFO3 = {"RestartReason":"Software/System restart"}
    19:57:09 RSL: RESULT = {"POWER1":"OFF"}
    19:57:09 RSL: POWER1 = OFF
    19:57:09 RSL: RESULT = {"POWER2":"OFF"}
    19:57:09 RSL: POWER2 = OFF
    19:57:09 RSL: RESULT = {"POWER3":"OFF"}
    19:57:09 RSL: POWER3 = OFF
    19:57:09 RSL: RESULT = {"POWER4":"ON"}
    19:57:09 RSL: POWER4 = ON
    19:57:09 RUL: SYSTEM#BOOT performs "backlog power1 0; power3 0; power2 0; power4 0;"
    19:57:10 RSL: RESULT = {"POWER3":"OFF"}
    19:57:10 RSL: POWER3 = OFF
    19:57:10 RSL: RESULT = {"POWER4":"OFF"}
    19:57:10 RSL: POWER4 = OFF
    19:57:10 RSL: RESULT = {"POWER2":"OFF"}
    19:57:10 RSL: POWER2 = OFF
    19:57:17 RSL: STATE = {"Time":"2019-11-24T19:57:17","Uptime":"0T00:00:15","UptimeSec":15,"Heap":28,"SleepMode":"Dynamic","Sleep":200,"LoadAvg":4,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"RSSI":82,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Was nicht mehr passiert das Schalten nach neuer WLAN Verbindung, da sieht es so aus:
    00:00:00 CFG: aus Flash geladen am F6, zählen 504
    20:36:19 RSL: INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.7.1(sonoff)","FallbackTopic":"cmnd/DVES_CE02EB_fb/","GroupTopic":"sonoffs"}
    20:36:19 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-0747","IPAddress":"192.168.178.102"}
    20:36:19 RSL: INFO3 = {"RestartReason":"Software/System restart"}
    20:36:19 RSL: RESULT = {"POWER1":"OFF"}
    20:36:19 RSL: POWER1 = OFF
    20:36:19 RSL: RESULT = {"POWER2":"OFF"}
    20:36:19 RSL: POWER2 = OFF
    20:36:19 RSL: RESULT = {"POWER3":"OFF"}
    20:36:19 RSL: POWER3 = OFF
    20:36:19 RSL: RESULT = {"POWER4":"ON"}
    20:36:19 RSL: POWER4 = ON
    20:36:19 RUL: SYSTEM#BOOT performs "backlog power1 0; power3 0; power2 0; power4 0;"
    20:36:20 RSL: RESULT = {"POWER4":"OFF"}
    20:36:20 RSL: POWER4 = OFF
    20:36:20 RSL: RESULT = {"POWER3":"OFF"}
    20:36:20 RSL: POWER3 = OFF
    20:36:20 RSL: RESULT = {"POWER2":"OFF"}
    20:36:20 RSL: POWER2 = OFF
    20:36:27 RSL: STATE = {"Time":"2019-11-24T20:36:27","Uptime":"0T00:00:15","UptimeSec":15,"Heap":28,"SleepMode":"Dynamic","Sleep":200,"LoadAvg":4,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"RSSI":72,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Nach Stromlos sieht es so aus:
    00:00:00 CFG: aus Flash geladen am F5, zählen 497
    00:00:00 WIF: verbinden mit AP2 SSR in Modus 11N als sonoff-0747...
    20:18:33 RSL: INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.7.1(sonoff)","FallbackTopic":"cmnd/DVES_CE02EB_fb/","GroupTopic":"sonoffs"}
    20:18:33 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-0747","IPAddress":"192.168.178.102"}
    20:18:33 RSL: INFO3 = {"RestartReason":"Power on"}
    20:18:33 RSL: RESULT = {"POWER1":"OFF"}
    20:18:33 RSL: POWER1 = OFF
    20:18:33 RSL: RESULT = {"POWER2":"OFF"}
    20:18:33 RSL: POWER2 = OFF
    20:18:33 RSL: RESULT = {"POWER3":"OFF"}
    20:18:33 RSL: POWER3 = OFF
    20:18:33 RSL: RESULT = {"POWER4":"OFF"}
    20:18:33 RSL: POWER4 = OFF
    20:18:33 RUL: SYSTEM#BOOT performs "backlog power1 0; power3 0; power2 0; power4 0;"
    20:18:34 RSL: RESULT = {"POWER2":"OFF"}
    20:18:34 RSL: POWER2 = OFF
    20:18:34 RSL: RESULT = {"POWER4":"OFF"}
    20:18:34 RSL: POWER4 = OFF
    20:18:41 RSL: STATE = {"Time":"2019-11-24T20:18:41","Uptime":"0T00:00:15","UptimeSec":15,"Heap":28,"SleepMode":"Dynamic","Sleep":200,"LoadAvg":4,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":2,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":70,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Vielleicht bekommen wir das ungewollte Tasten/Schalten nach dem flashed und neuer WLAN Verbindung auch noch hin. Bei Deinen hervorragenden Kenntnissen bin ich zuversichtlich.
    Hallo Jörg,
    mein zweiter Schalter zeigt das gleiche Verhalten.
    00:00:00 CFG: aus Flash geladen am F5, zählen 377
    22:03:35 RSL: INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.7.1(sonoff)","FallbackTopic":"cmnd/DVES_CE02EB_fb/","GroupTopic":"sonoffs"}
    22:03:35 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-0747","IPAddress":"192.168.178.102"}
    22:03:35 RSL: INFO3 = {"RestartReason":"Software/System restart"}
    22:03:35 RSL: RESULT = {"POWER1":"OFF"}
    22:03:35 RSL: POWER1 = OFF
    22:03:35 RSL: RESULT = {"POWER2":"OFF"}
    22:03:35 RSL: POWER2 = OFF
    22:03:35 RSL: RESULT = {"POWER3":"OFF"}
    22:03:35 RSL: POWER3 = OFF
    22:03:35 RSL: RESULT = {"POWER4":"ON"}
    22:03:35 RSL: POWER4 = ON
    22:03:36 RSL: RESULT = {"POWER4":"OFF"}
    22:03:36 RSL: POWER4 = OFF
    22:03:43 RSL: STATE = {"Time":"2019-11-22T22:03:43","Uptime":"0T00:00:15","UptimeSec":15,"Heap":28,"SleepMode":"Dynamic","Sleep":200,"LoadAvg":5,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":2,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":6,"RSSI":74,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Hier das Ergebnis nach Neustart. Die Relais Tasten "Ein"
    00:00:00 CFG: aus Flash geladen am F7, zählen 85
    00:00:00 Projekt sonoff Tuer Garage Tuer Licht Version 6.7.1(sonoff)-STAGE
    00:00:00 WIF: verbinden mit AP1 SSR in Modus 11N als sonoff-4691...
    00:00:03 RSL: stat/sonoff/RESULT = {"POWER1":"ON"}
    00:00:03 RSL: stat/sonoff/POWER1 = ON
    00:00:03 RSL: stat/sonoff/RESULT = {"POWER2":"ON"}
    00:00:03 RSL: stat/sonoff/POWER2 = ON
    00:00:03 RSL: stat/sonoff/RESULT = {"POWER3":"ON"}
    00:00:03 RSL: stat/sonoff/POWER3 = ON
    00:00:03 RSL: stat/sonoff/RESULT = {"POWER4":"ON"}
    00:00:03 RSL: stat/sonoff/POWER4 = ON
    00:00:04 RSL: stat/sonoff/RESULT = {"POWER1":"OFF"}
    00:00:04 RSL: stat/sonoff/POWER1 = OFF
    00:00:04 RSL: stat/sonoff/RESULT = {"POWER2":"OFF"}
    00:00:04 RSL: stat/sonoff/POWER2 = OFF
    00:00:04 RSL: stat/sonoff/RESULT = {"POWER3":"OFF"}
    00:00:04 RSL: stat/sonoff/POWER3 = OFF
    00:00:04 HTP: Web-Server aktiv bei sonoff-4691 mit IP-Adresse 192.168.178.103
    21:45:53 RSL: stat/sonoff/RESULT = {"POWER4":"OFF"}
    21:45:53 RSL: stat/sonoff/POWER4 = OFF
    Hallo Jörg,
    ich habe jetzt nochmal den Befehl eingegeben. Nachfolgend die Konsole.
    00:00:00 CFG: aus Flash geladen am FB, zählen 81
    21:31:05 RSL: stat/sonoff/RESULT = {"POWER4":"OFF"}
    21:31:05 RSL: stat/sonoff/POWER4 = OFF
    21:35:57 RSL: tele/sonoff/STATE = {"Time":"2019-11-22T21:35:57","Uptime":"0T00:04:59","UptimeSec":299,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"38:10:D5:F6:90:DE","Channel":6,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:05"}}
    21:40:57 RSL: tele/sonoff/STATE = {"Time":"2019-11-22T21:40:57","Uptime":"0T00:09:59","UptimeSec":599,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":11,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"38:10:D5:F6:90:DE","Channel":6,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:05"}}
    21:40:58 APP: Serielles Logging deaktiviert
    21:41:58 CMD: rule1 on system#boot do backlog power1 0; power3 0; power2 0; power4 0; endon
    21:41:58 RSL: stat/sonoff/RESULT = {"Rule1":"OFF","Once":"OFF","StopOnError":"OFF","Free":439,"Rules":"on system#boot do backlog power1 0; power3 0; power2 0; power4 0; endon"}
    21:42:46 CMD: rule1 1
    21:42:46 RSL: stat/sonoff/RESULT = {"Rule1":"ON","Once":"OFF","StopOnError":"OFF","Free":439,"Rules":"on system#boot do backlog power1 0; power3 0; power2 0; power4 0; endon"}
    Hallo Jörg, die beiden Zeilen, die Du mir bezüglich Rule geschrieben hast habe ich eingegeben. Alle 4 Power habe ich auf 0 gesetzt. Mir fehlt bezüglich Rule das Hintergrundwissen. Die beiden Schalter haben unterschiedliche IP. Mit Interlock habe ich nichts getan und ich habe diesbezüglich keine Kenntnisse. Hausautomatisierungssoftware habe ich keine laufen. Merkwürdig ist, dass nach
    Warmstart die vorher geschalteten Relais beim Neustart einschalten bzw. Tasten.
    Gerade haben Relais 1-3 geschaltet, dann kommt nach dem Neustart nachfolgender Ablauf aus der Konsole.
    00:00:00 CFG: aus Flash geladen am F8, zählen 76
    21:26:33 RSL: stat/sonoff/RESULT = {"POWER3":"OFF"}
    21:26:33 RSL: stat/sonoff/POWER3 = OFF
    Kannst Du das Interpretieren und mir vielleicht bezüglich Rule noch eine Info zukommen lassen? Würde mich freuen. Danke im Voraus.
    Hallo, S6 = 1, K5 all 0. und K6 all 1.
    die Relais sollen bei mir als Taster funktionieren. Jetzt habe ich nich festgestellt, dass nach einem Kaltstart (Strom aus) die Relais erst mal nicht schalten. Wenn dann die Relais über das Webinterface geschaltet werden und danach ein Warmstart durchgeführt wird, Tasten die vorher geschalteten Relais erst mal ein. Hier ein Auszug aus der Konsole. Ich hatte Relais 1 und zwei geschaltet.
    00:00:00 CFG: aus Flash geladen am F4, zählen 72
    15:46:59 RSL: tele/sonoff/STATE = {"Time":"2019-11-22T15:46:59","Uptime":"0T00:04:59","UptimeSec":299,"Heap":27,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"38:10:D5:F6:90:DE","Channel":1,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:05"}}
    Habe ich gemacht. Danach sieht es so aus.
    00:00:00 CFG: aus Flash geladen am F9, zählen 27
    Jetzt habe ich ein das Relais 1 über das Webinterface geschaltet. Danach sieht es so aus.
    14:23:47 RSL: tele/sonoff/STATE = {"Time":"2019-11-22T14:23:47","Uptime":"0T00:04:59","UptimeSec":299,"Heap":28,"SleepMode":"Dynamic","Sleep":250,"LoadAvg":3,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"38:10:D5:F6:90:DE","Channel":6,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:05"}}
    14:24:33 RSL: stat/sonoff/RESULT = {"POWER1":"ON"}
    14:24:33 RSL: stat/sonoff/POWER1 = ON
    14:24:34 RSL: stat/sonoff/RESULT = {"POWER1":"OFF"}
    14:24:34 RSL: stat/sonoff/POWER1 = OFF
    Wenn nach dem Schalten ein Neustart ausgeführt wird schaltet Relais 1 wieder1
    00:00:00 CFG: aus Flash geladen am F6, zählen 30
    Das Relais 1 hat wieder geschaltet. Ich verstehe es nicht.
    Hallo JoergZ,
    danke für die schnelle Antwort. Es hat nicht geklappt. Hier der Auszug aus der Konsole. Das waren meine Befehle.
    00:00:00 CFG: aus Flash geladen am F7, zählen 13
    00:00:00 Projekt sonoff Sonoff Version 6.7.1(sonoff)-STAGE
    00:00:02 RSL: stat/sonoff/RESULT = {"POWER1":"ON"}
    00:00:02 RSL: stat/sonoff/POWER1 = ON
    13:41:50 CMD: savedata 1
    13:41:50 RSL: stat/sonoff/RESULT = {"SaveData":"ON"}
    13:42:04 CMD: PowerOnState0
    13:42:04 RSL: stat/sonoff/RESULT = {"PowerOnState":0}
    Nach dem Neustart hat wieder Relais 1 geschaltet. Siehe Zeile 4. Was mache ich falsch bzw. wo liegt das Problem?
    00:00:00 CFG: aus Flash geladen am F6, zählen 14
    Danke für die Hilfe.
    Hallo, ich habe zwei Sonor Tasmota 4CH verbaut, die ich gerne als Türöffner als Tasterfunktion für Garagentor, Haustür und Nebeneingangstür nutzen möchte. Einen weiteren Schalter habe ich zum Fernschalten von Beleuchtung und Sauna verbaut. Beide Schalter laufen mit Tasmota 6.71.
    Bei Neustart schalten die beiden Schalter die Kontakte. Da dies bei Stromausfall oder neuer IP-Adresse vom Provider passiert können die Schalter für meine geplanten kritischen Anwendungen (Türen und Saunaofen) nicht genutzt werden. Kann mir jemand aus dem Forum helfen um die einmaligen Schaltungen beim Neustart zu verhindern. Als Anlage ein Auszug aus der Konsole nach einem Neustart. In der vierten Zeile werden die Schalter 1 und 2 eingeschaltet. Da sie als Taster konfiguriert sind führt es zum Einschalten der angeschlossenen Geräte. Danke für Eure Aufmerksamkeit.
    00:00:00 CFG: aus Flash geladen am F5, zählen 25
    00:00:00 Projekt sonoff Tür-Garage-Tuer-Licht Version 6.7.1(sonoff)-STAGE
    00:00:03 RSL: RESULT = {"POWER1":"ON"}
    00:00:03 RSL: POWER1 = ON
    00:00:03 RSL: RESULT = {"POWER2":"ON"}
    00:00:03 RSL: POWER2 = ON
    16:11:48 RSL: INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.7.1(sonoff)","FallbackTopic":"cmnd/DVES_CA3253_fb/","GroupTopic":"sonoffs"}
    16:11:48 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-4691","IPAddress":"192.168.178.103"}
    16:11:48 RSL: INFO3 = {"RestartReason":"Software/System restart"}
    16:11:48 RSL: RESULT = {"POWER1":"ON"}
    16:11:48 RSL: POWER1 = ON
    16:11:48 RSL: RESULT = {"POWER2":"ON"}
    16:11:48 RSL: POWER2 = ON
    16:11:48 RSL: RESULT = {"POWER3":"OFF"}
    16:11:48 RSL: POWER3 = OFF
    16:11:48 RSL: RESULT = {"POWER4":"OFF"}
    16:11:48 RSL: POWER4 = OFF
    16:11:49 RSL: RESULT = {"POWER1":"OFF"}
    16:11:49 RSL: POWER1 = OFF
    16:11:49 RSL: RESULT = {"POWER2":"OFF"}
    16:11:49 RSL: POWER2 = OFF
    16:11:56 RSL: STATE = {"Time":"2019-11-21T16:11:56","Uptime":"0T00:00:15","UptimeSec":15,"Heap":28,"SleepMode":"Dynamic","Sleep":200,"LoadAvg":4,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"38:10:D5:F6:90:DE","Channel":6,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:05"}}
