Zu wificonfig
09:24:52 CMD: wificonfig
09:24:52 RSL: RESULT = {"WifiConfig":"5 (Wait)"}
Zu MQTT
In den >> Sonstige Einstellungen << ist >> MQTT aktivieren << nicht ausgewählt.
Zu wificonfig
Zu MQTT
Hallo HoerMirAuf,
heute morgen war das Licht an somit scheinst du recht gehabt zu haben.
Schon einmal danke dafür.
Jetzt zeigt der Log folgendes an, ist das dann so OK ?
00:00:00 Projekt sonoff Kueche-Licht Version 6.5.0(sonoff)-2_3_0
00:00:00 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
00:00:06 WIF: verbunden
00:00:06 HTP: Web-Server aktiv bei sonoff-7298 mit IP-Adresse 192.168.178.120
00:00:06 UPP: Multicast (wieder-)verbunden
00:00:06 RSL: INFO1 = {"Module":"Shelly 1","Version":"6.5.0(sonoff)","FallbackTopic":"cmnd/DVES_259C82_fb/","GroupTopic":"sonoffs"}
00:00:06 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-7298","IPAddress":"192.168.178.120"}
00:00:06 RSL: INFO3 = {"RestartReason":"Software/System restart"}
00:00:06 RSL: RESULT = {"POWER":"OFF"}
00:00:06 RSL: POWER = OFF
05:17:16 RSL: STATE = {"Time":"2019-04-11T05:17:16","Uptime":"0T00:00:15","Vcc":3.250,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"OFF","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":52,"LinkCount":1,"Downtime":"0T00:00:06"}}
05:17:16 RSL: SENSOR = {"Time":"2019-04-11T05:17:16","Switch1":"ON"}
05:20:00 RSL: RESULT = {"POWER":"ON"}
05:20:00 RSL: POWER = ON
05:22:16 RSL: STATE = {"Time":"2019-04-11T05:22:16","Uptime":"0T00:05:15","Vcc":3.284,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":48,"LinkCount":1,"Downtime":"0T00:00:06"}}
05:22:16 RSL: SENSOR = {"Time":"2019-04-11T05:22:16","Switch1":"ON"}
05:23:03 UPP: Multicast (wieder-)verbunden
05:27:01 APP: Serielles Logging deaktiviert
05:27:16 RSL: STATE = {"Time":"2019-04-11T05:27:16","Uptime":"0T00:10:15","Vcc":3.281,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":46,"LinkCount":2,"Downtime":"0T00:00:09"}}
05:27:16 RSL: SENSOR = {"Time":"2019-04-11T05:27:16","Switch1":"ON"}
05:32:16 RSL: STATE = {"Time":"2019-04-11T05:32:16","Uptime":"0T00:15:15","Vcc":3.252,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":46,"LinkCount":2,"Downtime":"0T00:00:09"}}
05:32:16 RSL: SENSOR = {"Time":"2019-04-11T05:32:16","Switch1":"ON"}
05:37:16 RSL: STATE = {"Time":"2019-04-11T05:37:16","Uptime":"0T00:20:15","Vcc":3.273,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":46,"LinkCount":2,"Downtime":"0T00:00:09"}}
05:37:16 RSL: SENSOR = {"Time":"2019-04-11T05:37:16","Switch1":"ON"}05:13:03 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:09 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:10 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:17 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:17 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:23 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:24 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:30 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:31 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:38 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:38 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:44 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:45 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:52 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:52 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:13:58 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:13:59 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:06 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:06 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:12 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:13 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:19 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:20 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:27 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:27 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:33 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:34 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:40 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:41 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:48 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:48 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:14:54 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:14:55 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:15:02 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:15:02 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:15:09 WIF: Verbindung fehlgeschlagen, da AP nicht erreicht werden konnte
05:15:09 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:15:17 WIF: Verbindung fehlgeschlagen, da das Passwort falsch ist
05:15:18 WIF: Verbindung fehlgeschlagen, da das Passwort falsch ist
05:15:20 WIF: verbinden mit AP1 00-Fritz-024 in Modus 11N wie sonoff-7298...
05:15:24 WIF: verbunden
05:15:24 UPP: Multicast (wieder-)verbunden
05:17:20 RSL: STATE = {"Time":"2019-04-12T05:17:20","Uptime":"1T00:00:19","Vcc":3.248,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"OFF","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":50,"LinkCount":3,"Downtime":"0T06:15:19"}}
05:17:20 RSL: SENSOR = {"Time":"2019-04-12T05:17:20","Switch1":"ON"}
05:22:20 RSL: STATE = {"Time":"2019-04-12T05:22:20","Uptime":"1T00:05:19","Vcc":3.374,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":48,"LinkCount":3,"Downtime":"0T06:15:19"}}
05:22:20 RSL: SENSOR = {"Time":"2019-04-12T05:22:20","Switch1":"ON"}
05:24:40 UPP: Multicast (wieder-)verbunden
Alles anzeigen
Dann bekomme ich
21:24:40 CMD: wificonfig
21:24:40 RSL: RESULT = {"WifiConfig":"2 (WifiManager)"}
angezeigt
wie oben von motorrad schon geschrieben, habe ich das gleiche Problem, bei meinem Shelly den ich seit einer Woche habe.
Hallo
bei einem Shelly ist ohne Wlan kein einschalten mit Lichtschalter möglich.
Wie kann ich das ändern?
Ich habe auf meinem Shelly "Sonoff-Tasmota 6.5.0" und wenn ich über einen Timer den Shelly schalten möchte und der Shelly kein Wlan hat, läuft nichts.
Ich schalte Abends bis morgens 5:00 Uhr mein Wlan ab. Der Shelly soll nun eigentlich um 05:10 Uhr das Licht in der Küche EIN schalten, macht aber nichts. Manuell kann ich das Licht schalten und danach läuft auch das schalten über die Web Oberfläche.
Als LOG bekomme ich von der Konsole folgendes:
00:00:10 WIF: verbunden
00:00:10 HTP: Web-Server aktiv bei sonoff-7298 mit IP-Adresse 192.168.178.120
00:00:10 UPP: Multicast (wieder-)verbunden
00:00:10 RSL: INFO1 = {"Module":"Shelly 1","Version":"6.5.0(sonoff)","FallbackTopic":"cmnd/DVES_259C82_fb/","GroupTopic":"sonoffs"}
00:00:10 RSL: INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-7298","IPAddress":"192.168.178.120"}
00:00:10 RSL: INFO3 = {"RestartReason":"Software/System restart"}
00:00:10 RSL: RESULT = {"POWER":"ON"}
00:00:10 RSL: POWER = ON
05:17:30 RSL: STATE = {"Time":"2019-04-10T05:17:30","Uptime":"0T00:00:19","Vcc":3.285,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":40,"LinkCount":1,"Downtime":"0T00:00:10"}}
05:17:30 RSL: SENSOR = {"Time":"2019-04-10T05:17:30","Switch1":"OFF"}
05:22:30 RSL: STATE = {"Time":"2019-04-10T05:22:30","Uptime":"0T00:05:19","Vcc":3.255,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":11,"RSSI":44,"LinkCount":1,"Downtime":"0T00:00:10"}}
05:22:30 RSL: SENSOR = {"Time":"2019-04-10T05:22:30","Switch1":"OFF"}
05:26:37 UPP: Multicast (wieder-)verbunden
05:27:11 APP: Serielles Logging deaktiviert
05:27:30 RSL: STATE = {"Time":"2019-04-10T05:27:30","Uptime":"0T00:10:19","Vcc":3.274,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":50,"LinkCount":2,"Downtime":"0T00:00:19"}}
05:27:30 RSL: SENSOR = {"Time":"2019-04-10T05:27:30","Switch1":"OFF"}
05:32:30 RSL: STATE = {"Time":"2019-04-10T05:32:30","Uptime":"0T00:15:19","Vcc":3.272,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":46,"LinkCount":2,"Downtime":"0T00:00:19"}}
05:32:30 RSL: SENSOR = {"Time":"2019-04-10T05:32:30","Switch1":"OFF"}
05:37:30 RSL: STATE = {"Time":"2019-04-10T05:37:30","Uptime":"0T00:20:19","Vcc":3.252,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"POWER":"ON","Wifi":{"AP":1,"SSId":"00-Fritz-024","BSSId":"5C:49:79:E8:AE:0E","Channel":1,"RSSI":50,"LinkCount":2,"Downtime":"0T00:00:19"}}
Alles anzeigen
Ich könnte natürlich das Wlan schon ab 04:00 Uhr wieder einschalten, aber das ist ja eigentlich nicht im Sinne des Erfinders.
Was läuft hier also falsch ?
Ach ja, das AUS schalten mittels Timer funktioniert (mit Wlan )
Schon einmal danke für eure Tips.
Shelly_2019
