> Executing task: C:\Users\mymey\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing tasmota32-DE (framework: arduino; platform: espressif32@1.12.4; board: esp32cam)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/es…2/esp32cam.html
PLATFORM: Espressif 32 1.12.4 > AI Thinker ESP32-CAM
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 3.10004.200129 (1.0.4)
- tool-esptoolpy 1.20800.0 (2.8.0)
- tool-mkspiffs 2.230.0 (2.30)
- toolchain-xtensa32 2.50200.80 (5.2.0)
Converting tasmota.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 85 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <ESP32-to-ESP8266-compat> 0.0.2
|-- <Unishox Compressor Decompressor highly customized and optimized for ESP8266 and Tasmota> 1.0
|-- <Wire> 1.0.1
Building in release mode
*** use provided user_config_override.h as planned ***
Compiling .pioenvs\tasmota32-DE\src\tasmota.ino.cpp.o
In file included from C:/Sonoff-Tasmota-universal8/tasmota/tasmota.ino:41:0:
tasmota\my_user_config.h:39:0: warning: "USE_CONFIG_OVERRIDE" redefined
#define USE_CONFIG_OVERRIDE // Uncomment to use user_config_override.h file. See README.md
<command-line>:0:0: note: this is the location of the previous definition
In file included from tasmota\my_user_config.h:807:0,
tasmota\user_config_override.h:24:2: warning: #warning **** user_config_override.h: Using Settings from this File **** [-Wcpp]
C:/Sonoff-Tasmota-universal8/tasmota/xdrv_10_scripter.ino:116:17: note: #pragma message: script compression option used
#pragma message "script compression option used"
Linking .pioenvs\tasmota32-DE\firmware.elf
Retrieving maximum program size .pioenvs\tasmota32-DE\firmware.elf
Building .pioenvs\tasmota32-DE\firmware.bin
Checking size .pioenvs\tasmota32-DE\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [== ] 17.9% (used 58696 bytes from 327680 bytes)
Flash: [====== ] 57.9% (used 1177058 bytes from 2031616 bytes)
esptool.py v2.8
bin_map_copy([".pioenvs\tasmota32-DE\firmware.bin"], [".pioenvs\tasmota32-DE\firmware.elf"])
bin_gzip([".pioenvs\tasmota32-DE\firmware.bin"], [".pioenvs\tasmota32-DE\firmware.elf"])
Configuring upload protocol...
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Use manually specified: /dev/cu.SLAB_USBtoUART
Uploading .pioenvs\tasmota32-DE\firmware.bin
esptool.py v2.8
Serial port /dev/cu.SLAB_USBtoUART
Traceback (most recent call last):
File "C:\Users\mymey\.platformio\packages\tool-esptoolpy\esptool.py", line 3201, in <module>
_main()
File "C:\Users\mymey\.platformio\packages\tool-esptoolpy\esptool.py", line 3194, in _main
main()
File "C:\Users\mymey\.platformio\packages\tool-esptoolpy\esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:\Users\mymey\.platformio\packages\tool-esptoolpy\esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "C:\Users\mymey\.platformio\penv\lib\site-packages\serial\__init__.py", line 88, in serial_for_url
instance.open()
File "C:\Users\mymey\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port '/dev/cu.SLAB_USBtoUART': FileNotFoundError(2, 'Das System kann den angegebenen Pfad nicht finden.', None, 3)
*** [upload] Error 1
=========================================================================== [FAILED] Took 98.74 seconds ===========================================================================
Environment Status Duration
tasmota IGNORED
tasmota-DE IGNORED
tasmota-debug IGNORED
tasmota32 IGNORED
tasmota32-DE FAILED 00:01:38.738
====================================================================== 1 failed, 0 succeeded in 00:01:38.738 ======================================================================
The terminal process "C:\Users\mymey\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
