Sonoff TH10/16 mit Sensor AM2301 zeigt NUll
  • Hallo, bin ein Neuling und habe das Problem mit dem Sensor, der an zwei THxx immer den Wert null zeigt. Habe schon alles beschriebene probiert. Sensorstecker! usw. Kann mir geholfen werden?
    Hier ein Auszug aus der Konsole:
    09:46:51.223 RSL: STATE = {"Time":"2024-09-24T09:46:51","Uptime":"0T00:00:10","UptimeSec":10,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":88,"Signal":-56,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:46:51.244 RSL: SENSOR = {"Time":"2024-09-24T09:46:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
    09:51:51.226 RSL: STATE = {"Time":"2024-09-24T09:51:51","Uptime":"0T00:05:10","UptimeSec":310,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":88,"Signal":-56,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:51:51.248 RSL: SENSOR = {"Time":"2024-09-24T09:51:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
    09:56:41.214 APP: Serielles Logging deaktiviert
    09:56:51.208 RSL: STATE = {"Time":"2024-09-24T09:56:51","Uptime":"0T00:10:10","UptimeSec":610,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SSR","BSSId":"98:9B:CB:DB:6F:55","Channel":1,"Mode":"11n","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
    09:56:51.212 RSL: SENSOR = {"Time":"2024-09-24T09:56:51","AM2301":{"Temperature":null,"Humidity":null,"DewPoint":null},"TempUnit":"C"}
