ESP32 Freenove-WROVER-Cam
  • Hallo Leute!
    Hätte evtl. jemand einen Tip für mich? Ich habe das ESP32 Freenove Wrover Cam Modul bekomme aber kein Bild.
    Habe es flaschen können und bin auch über USB verbunden. Soweit ist die Firmware drauf aber leider bekommen ich kein Bild.
    Hier ein Auszug vom Log:
    00:00:00.002 HDW: ESP32-D0WDQ6 (PSRAM)
    00:00:00.070 UFS: FlashFS mounted with 300 kB free
    00:00:00.093 CFG: Loaded from File, Count 54
    00:00:00.101 QPC: Count 1
    00:00:00.257 BRY: Berry initialized, RAM used=3427 bytes
    00:00:00.315 Project tasmota - ESPWebCam Version 12.4.0(webcam)-2_0_6(2023-02-24T15:35:24)
    00:00:03.091 WIF: Connecting to AP1 Lounge Channel 6 BSSId 3C:A6:2F:BC:2F:8F in mode 11n as tasmota-04623C-0572...
    00:00:06.886 QPC: Reset
    00:00:10.509 WIF: Connected
    00:00:10.765 HTP: Web server active on tasmota-04623C-0572 with IP address 192.168.220.145
    00:00:10.768 RSL: INFO1 = {"Info1":{"Module":"Freenove-WROVER-Cam","Version":"12.4.0(webcam)","FallbackTopic":"cmnd/DVES_04623C_fb/","GroupTopic":"cmnd/tasmotas/"}}
    00:00:10.782 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-04623C-0572","IPAddress":"192.168.220.145","IP6Global":"","IP6Local":"fe80::4222:d8ff:fe04:623c"}}
    00:00:10.805 RSL: INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":23}} 08:43:45.881 RSL: STATE = {"Time":"2023-03-23T08:43:45","Uptime":"0T00:00:15","UptimeSec":15,"Heap":168,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":34},"Wifi":{"AP":1,"SSId":"Lounge","BSSId":"3C:A6:2F:BC:2F:8F","Channel":6,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:11"}}
    Ich hab dieses Template geflasht:
    Freenove ESP32-WROVER.DEV Camera (FNK0060) Configuration for Tasmota
    Configure your smart camera to work with Tasmota open source firmware.
    templates.blakadder.com
    Im TasmotaMenü ist die Cam paramtriert, zeigt aber kein Bild an und die Framerate steht bei 0:
    Hätte jemand eine Idee?
  • ESPhome ESP32-WROVER-E camera failed - SOLVED
    Do you mean these two smd regulators? 65BX - XC6206P122MR 1.2V 54FK - XC6206P282MR 2.8V is there an easy way or are they soldered the other way around?…
    community.home-assistant.io
    Das muß ich jetzt prüfen! Der Link für alle die mal dieses Forum besuchen werden!
    Einmal editiert, zuletzt von Loco (23. März 2023 um 12:42) aus folgendem Grund: Ja, hab die Spg-Regler geprüft. Sind bei mir auch vertauscht! Muß ich umlöten - hab natürlich kein Lötkolben da für SMD. Mal schauen wie ich das hinkriege...
