witty ap ssid not coming up ip unset
  • Hi
    I flashed Tasmota on a witty via OTA .
    Witty was formerly running ESPEasy firmware.
    AP is not coming up. Do not see the SSID.
    Tasmota Version 8.1.0.2(tasmota)-2_6_1
    web server active on tasmota-4082 with IP address (IP unset)
    Did I miss anything?
    see serial log with Status 0
    After running status 0 the witty restarted.
    Thanks Thomas
    07:20:43.943 -> 00:00:00 CFG: Loaded from flash at F6, Count 6 07:20:43.943 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:20:44.109 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:20:44.607 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:23:46.374 -> 00:03:02 APP: Restarting 07:23:46.473 -> 07:23:46.473 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:23:46.473 -> 07:23:46.507 -> load 0x4010f000, len 1384, room 16 07:23:46.507 -> tail 8 07:23:46.507 -> chksum 0x2d 07:23:46.507 -> csum 0x2d 07:23:46.507 -> v482516e3 07:23:46.507 -> ~ld 07:23:46.639 -> 00:00:00 CFG: Loaded from flash at F5, Count 7 07:23:46.639 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:23:46.772 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:23:47.304 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:26:49.077 -> 00:03:02 APP: Restarting 07:26:49.176 -> 07:26:49.176 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:26:49.176 -> 07:26:49.209 -> load 0x4010f000, len 1384, room 16 07:26:49.209 -> tail 8 07:26:49.209 -> chksum 0x2d 07:26:49.209 -> csum 0x2d 07:26:49.209 -> v482516e3 07:26:49.209 -> ~ld 07:26:49.308 -> 00:00:00 CFG: Loaded from flash at F4, Count 8 07:26:49.342 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:26:49.474 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:26:49.974 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:29:51.779 -> 00:03:02 APP: Restarting 07:29:51.856 -> 07:29:51.856 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:29:51.856 -> 07:29:51.935 -> load 0x4010f000, len 1384, room 16 07:29:51.935 -> tail 8 07:29:51.935 -> chksum 0x2d 07:29:51.935 -> csum 0x2d 07:29:51.935 -> v482516e3 07:29:51.935 -> ~ld 07:29:52.014 -> 00:00:00 CFG: Loaded from flash at FB, Count 9 07:29:52.014 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:29:52.179 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:29:52.681 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset) 07:32:45.141 -> 00:02:53 CMD: status 0 07:32:45.141 -> 00:02:53 RSL: stat/tasmota/STATUS = {"Status":{"Module":18,"FriendlyName":["Tasmota"],"Topic":"tasmota","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}} 07:32:45.174 -> 00:02:53 RSL: stat/tasmota/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:02:54","StartupUTC":"","Sleep":50,"CfgHolder":4617,"BootCount":8,"SaveCount":10,"SaveAddress":"FA000"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS2 = {"StatusFWR":{"Version":"8.1.0.2(tasmota)","BuildDateTime":"2019-12-30T19:07:34","Boot":17,"Core":"2_6_1","SDK":"2.2.2-dev(38a443e)","Hardware":"ESP8266EX","CR":"287/699"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00000000"]}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS4 = {"StatusMEM":{"ProgramSize":452,"Free":548,"Heap":34,"ProgramFlashSize":1024,"FlashSize":4096,"FlashChipId":"1640EF","FlashMode":3,"Features":["00000809","0F400082","04048000","00000005","000000C0","00000080"],"Drivers":"1,2,3,4,9,10,12,16","Sensors":"1,2,3"}} 07:32:45.257 -> 00:02:53 RSL: stat/tasmota/STATUS5 = {"StatusNET":{"Hostname":"tasmota-4082","IPAddress":"(IP unset)","Gateway":"192.168.1.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.1.1","Mac":"4C:11:AE:0E:8F:F2","Webserver":2,"WifiConfig":2,"WifiPower":17.0}} 07:32:45.311 -> 00:02:53 RSL: stat/tasmota/STATUS6 = {"StatusMQT":{"MqttHost":"","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_0E8FF2","MqttUser":"DVES_USER","MqttCount":0,"MAX_PACKET_SIZE":1000,"KEEPALIVE":30}} 07:32:45.311 -> 00:02:53 RSL: stat/tasmota/STATUS7 = {"StatusTIM":{"UTC":"Thu Jan 01 00:02:53 1970","Local":"Thu Jan 01 00:02:53 1970","StartDST":"Thu Jan 01 00:00:00 1970","EndDST":"Thu Jan 01 00:00:00 1970","Timezone":"+00:00","Sunrise":"07:43","Sunset":"16:03"}} 07:32:45.342 -> 00:02:53 RSL: stat/tasmota/STATUS10 = {"StatusSNS":{"Time":"1970-01-01T00:02:53"}} 07:32:45.342 -> 00:02:53 RSL: stat/tasmota/STATUS11 = {"StatusSTS":{"Time":"1970-01-01T00:02:53","Uptime":"0T00:02:54","UptimeSec":174,"Heap":34,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"","BSSId":"B1:C8:A1:D8:91:E8","Channel":1,"RSSI":100,"Signal":31,"LinkCount":0,"Downtime":"0T00:00:00"}}} 07:32:54.686 -> 00:03:02 APP: Restarting 07:32:54.786 -> 07:32:54.786 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6) 07:32:54.786 -> 07:32:54.842 -> load 0x4010f000, len 1384, room 16 07:32:54.842 -> tail 8 07:32:54.842 -> chksum 0x2d 07:32:54.842 -> csum 0x2d 07:32:54.842 -> v482516e3 07:32:54.842 -> ~ld 07:32:54.952 -> 00:00:00 CFG: Loaded from flash at FA, Count 10 07:32:54.952 -> 00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1 07:32:55.118 -> 00:00:00 WIF: WifiManager active for 3 minutes 07:32:55.617 -> 00:00:00 HTP: Web server active on tasmota-4082 with IP address (IP unset)
  • What a horrible formatting of code! What's your system? OK without any joke:
    Seems that your device is half configured only:
    Your system restarts after 3 Minutes because you didn't do any settings. Look at the clock informations. Your device opens an own wifi-network. You have to connect after booting to this SSID with your smartphone for example and call the ip 192.168.4.1 . Now you can configure your device: Settings -> WiFi. Set a SSID which is valide and choose if you want to use DHCP or permanent IP. (Check the commands manual). If you use MainMenue -> Console you should use the command:
     wificonfig 4 <enter> #or 5
    After the next reboot your device will connect to your local wifi succesfully (if the values were correct!)
  • Hi Jörg,
    ok thanks.
    I expected the ssid as AP : tasmota-4082
    but no AP was showing up
    That is what confused me.
    I managed now to get a wifi connection working via serial and got a hint in an issue
    that probably due to old firmware and sdk on the ESP the config was messed up.
    Looks like I have to delete old settings. But I am looking for an OTA way to migrate the ESPs from ESP-Easy to tasmota without serial connection...
    Thanks Thomas
