[Info] Tasmota v7.1.2 RELEASE
  • Hi, Tasmota 7.1.0 (Betty) ist online:
    edit: inzwischen Tasmota v7.1.1 (Betty) Release
    und Tasmota v7.1.2 (Betty) Release
    https://github.com/arendst/Tasmota/releases
    .bin Download und OTA-link: http://thehackbox.org/tasmota/release/
    Es gibt jetzt ein 'offizielles Upload-Tool': Tasmota PyFlasher
    (Variante des NodeMCU PyFlasher, ohne die sonst nötigen Einstellungen)
    Auffälligste Änderung ab Version 7 ist, wie schon an anderer Stelle beschrieben,
    das "Dark theme" -> falls nach Update noch das helle Thema angezeigt wird,
    kommt man mit WebColor 0 schnell zum dunklen Thema.
    Außerdem wurde auch passend GitHub umgestellt (Black Friday ;) ) https://tasmota.github.io/docs/#/Home
    Changelog:
    Spoiler anzeigen
    Version 7.1.2 Betty
    • Fix lost functionality of GPIO9 and GPIO10 on some devices (#7080)
    • Fix Zigbee uses Hardware Serial if GPIO 1/3 or GPIO 13/15 and SerialLog 0 (#7071)
    • Fix WS2812 power control (#7090)
    • Change light color schemes 2, 3 and 4 from color wheel to Hue driven with user Saturation control
    • Change log buffer size from 520 to 700 characters accomodating full rule text (#7110)
    Version 7.1.1 Betty
    • Fix slider for devices with one or two channels like only white or white/yellow
    • Fix TasmotaSlave buffer overrun on Tele
    • Fix light scheme 4 speed (#7072)
    • Add support for TasmotaSlave executing commands on Tasmota
    Version 7.1.0 Betty
    • Remove update support for versions before 6.0
    • Remove driver xsns_12_ads1115_i2cdev replaced by xsns_12_ads1115
    • Remove most IR protocols from non dedicated IR firmware except NEC, RC5 and RC6
    • Change repository name from Sonoff-Tasmota to Tasmota and all code references from Sonoff to Tasmota
    • Change documentation from wiki to documentation repository by @blakadder
    • Change default GUI to dark theme
    • Change ArduinoSlave to TasmotaSlave
    • Change IRremoteESP8266 library to v2.7.1
    • Change supported PCF8574 I2C address range to 0x20 - 0x26 allowing other I2C devices with address 0x27 to be used at the same time
    • Change supported PCF8574A I2C address range to 0x39 - 0x3F allowing other I2C devices with address 0x38 to be used at the same time
    • Change supported MCP230xx I2C address range to 0x20 - 0x26 allowing other I2C devices with address 0x27 to be used at the same time
    • Change Reset erase end address from as seen by SDK (getFlashChipSize) to full flash size (getFlashChipRealSize)
    • Change new Fade system much smoother, Speed now up to 40 (#6942, #3714)
    • Fix better control of RGB/White when SetOption37 >128, added Dimmer1 and Dimmer2 commands (#6714)
    • Fix random crash caused by UPNP flood
    • Fix check deepsleep for valid values in Settings (#6961)
    • Fix Wifi instability when light is on, due to Sleep 0 (#6961, #6608)
    • Fix auto-power on/off when setting channel to non-zero or zero value, when SetOption68 1
    • Fix postpone saving settings to flash until Fade is complete, avoids pause in Fade
    • Add support for Tuya battery powered devices (#6735)
    • Add support for Honeywell I2C HIH series Humidity and Temperetaure sensor (#6808)
    • Add support for Honeywell HPMA115S0 particle concentration sensor by David Hunt (#6843)
    • Add support for I2C sensor TLS2591 Light Intensity sensor (#6873)
    • Add command SetOption73 0/1 to re-enable HTTP Cross-Origin Resource Sharing (CORS) now default disabled (#6767)
    • Add command SetOption74 0/1 to enable DS18x20 internal pull-up and remove define DS18B20_INTERNAL_PULLUP (#6795)
    • Add command SetOption75 0/1 to switch between grouptopic (0) using fulltopic replacing %topic% or (1) is cmnd/<grouptopic> (#6779)
    • Add command SetOption76 0/1 to enable incrementing bootcount when deepsleep is enabled (#6930)
    • Add command SetOption77 0/1 to keep power on when slider is far left
    • Add command I2cDriver for I2C driver runtime control using document I2CDEVICES.md
    • Add command TempOffset -12.6 .. 12.6 to set global temperature sensor offset (#6958)
    • Add command WebColor19 to control color of Module and Name (#6811)
    • Add command WifiPower 0 .. 20.5 to set Wifi Output Power which will be default set to 17dBm
    • Add frequency to ADE7953 energy monitor as used in Shelly 2.5 by ljakob (#6778)
    • Add hide Alexa objects with friendlyname starting with '$' (#6722, #6762)
    • Add Zigbee command support, considered as v1.0 for full Zigbee support
    • Add hardware detection to be overruled with SetOption51 (#6969)
    • Add Colorpicker to WebUI by Christian Staars (#6984)
  • bei den MagicHome Controller soll wohl noch ne bessere Unterstützung für weiß kommen. Das geht im Moment weder über Alexa noch über das Webinterface, weil es kein Slider für rein weiß gibt. Das wäre z.B. eine relevante Änderung zumindest für mich.
  • RGBW ist das Problem, nur ein weißer Streifen ist kein Problem. RGB geht auch ohne Probleme, nur das Weiß bei RGBW geht noch nicht über Alexa weil der dazugehörige Slider noch nicht implementiert ist. Im IOBroker ist RGBW allerdings voll steuerbar.
  • würde ich nen Reset 5 machen
    Reset 5 ist immer gut,
    wenn man aber nur das Farbschema auf default setzen will,
    dann reicht WebColor 0.
    Wer Probleme mit dem WLAN hat, kann übrigens
    Reset 3 probieren, damit wird das WiFi im ESP82xx neu kalibriert
    (Stromversorgung muss danach kurz komplett getrennt werden).
  • NoitaercX 1. Dezember 2019 um 14:46
    Hat den Titel des Themas von „[Info] Tasmota v7.1.0 RELEASE“ zu „[Info] Tasmota v7.1.1 RELEASE“ geändert.
  • Frage an diejenigen die selber compilieren:
    Verwende ja ausschließlich nodemcu's die ja 4MByte Flash haben. Wo stellt Ihr das in der platformio bzw platformio_override ein?
    Ich habe mal hier:
    und hier:
    editiert.
    SInd das die richtigen stellen oder geht das Zentral irgendwo anders einfacher?
  • NoitaercX 7. Dezember 2019 um 14:27
    Hat den Titel des Themas von „[Info] Tasmota v7.1.1 RELEASE“ zu „[Info] Tasmota v7.1.2 RELEASE“ geändert.
  • geht das Zentral irgendwo anders einfacher?
    Nein, zentraler als in der platformio_override geht nicht. Online mit TasmotaCompiler allenfalls.
    Ich denke du brauchst die esp8266.flash.4m1m.ld, dann:
    [core_2_6_1]
    ; *** Esp8266 core for Arduino version 2.6.1
    platform                  = espressif8266@2.3.0
    build_flags               = ${esp82xx_defaults.build_flags}
                               -Wl,-Teagle.flash.4m1m.ld
    ABER, wenn hier auch einige was anderes behaupten,
    es macht einfach zu wenig Sinn den Flash auf 4MB zu erweitern.
    Die Probleme, falls man dann doch mal wieder (versehentlich) eine 1MB Tasmota flasht,
    stehen in keiner Relation zu den paar Vorteilen.
    Deshalb gibt es auch von offizieller Tasmota Seite keinen Support und
    auch keine 4MB vorkompilierten .bins mehr.
  • SInd das die richtigen stellen oder geht das Zentral irgendwo anders einfacher?
    Ich mach das über die "platformio_tasmota_env.ini"! Hab dort am Ende folgendes eingefügt:
    Somit kann ich mit dem Befehl "Build" ganz normale 1MB Binarys erstellen und über "RunTask" ganz einfach auch 4MB Bins erstellen ...
