Tasmota v6.5.0 wurde heute veröffentlicht.
https://github.com/arendst/Sonoff-Tasmota/releases
Wieder mit default Core Version 2.3.0
(endlich )
.bin zum Direkt-Download oder OTA-Update
http://thehackbox.org/tasmota/release/
Changelog:
Spoiler anzeigen
Version 6.5.0 20190319
- Remove commands SetOption14 and SetOption63 as it has been superseded by command Interlock
- Remove command SetOption35 0-255 for mDNS start-up delay (#4793)
- Remove support for MQTT_LIBRARY_TYPE, MQTT_ARDUINOMQTT and MQTT_TASMOTAMQTT (#5474)
- Change webserver content handling from single String to small Chunks increasing RAM
- Change code use of boolean to bool and byte to uint8_t
- Change code uint8_t flags to bool flags
- Change sonoff_template.h layout regarding optional module flags like ADC0
- Change sonoff_template.h module lay-out by removing non-configurable GPIOs
- Change button driver making it modular
- Change switch driver making it modular and introduce input filter (#4665, #4724)
- Change switch input detection by optimizing switch debounce (#4724)
- Change web authentication (#4865)
- Change image name BE_MINIMAL to FIRMWARE_MINIMAL and USE_xyz to FIRMWARE_xyz (#5106)
- Change GUI weblog from XML to plain text solving possible empty screens (#5154)
- Fix most compiler warnings
- Fix Display exception 28 when JSON value is NULL received
- Fix epaper driver (#4785)
- Fix HAss Sensor Discovery Software Watchdog restart (#4831, #4988)
- Fix allowable MAX_RULE_VARS to 16 (#4933)
- Fix mDNS addService (#4938, #4951)
- Fix HAss discovery of MHZ19(B) sensors (#4992)
- Fix some exceptions and watchdogs due to lack of stack space (#5215)
- Fix GUI wifi password acception starting with asteriks (*) (#5231, #5242)
- Fix command WebSend intermittent results (#5273, #5304)
- Fix additional characters in fallbacktopic, hostname and mqttclient on core 2.5.0 (#5359, #5417)
- Fix Energy TotalStartTime when commands EnergyReset0 and/or EnergyReset3 used (#5373)
- Fix DS18S20 temperature calculation (#5375)
- Fix float calculations in range from 0 to -1 (#5386)
- Fix exception on GUI Configure Logging and Configure Other (#5424)
- Add commands PowerCal, VoltageCal and CurrentCal for HLW8012, HJL01 and BL0937 based energy sensors
- Add command SerialDelimiter 128 to filter reception of only characters between ASCII 32 and 127 (#5131)
- Add command SSerialSend5 <hexdata> to SerialBridge
- Add command Interlock 0 / 1 / 1,2 3,4 .. to control interlock ON/OFF and add up to 8 relays in 1 to 4 interlock groups (#4910, #5014)
- Add command Template 255 to copy module configuration over to current active template and store as user template named Merged (#5371)
- Add command WifiConfig 7 to allow reset of device in AP mode without admin password (#5297)
- Add command SetOption36 to control boot loop default restoration (#4645, #5063)
- Add command SetOption37 for RGBCW color mapping (#5326)
- Add command SetOption55 0/1 and define MDNS_ENABLE to disable/enable mDNS (#4793, #4923)
- Add command SetOption62 0/1 to disable retain on Button or Switch hold messages (#5299)
- Add support for Smanergy KA10 Smart Wall Socket with Energy monitoring
- Add support for commands in sensor drivers
- Add support for MAX31855 K-Type thermocouple sensor using softSPI (#4764)
- Add support for Near Field Communication (NFC) controller PN532 using Serial (#4791, #5162)
- Add support for OBI Power Socket 2 (#4829)
- Add support for YTF IR Bridge (#4855)
- Add support for Mi LED Desk Lamp with rotary switch (#4887)
- Add support for Digoo DG-SP202 Smart Socket with Energy monitoring (#4891)
- Add support for MAX44009 Ambient Light sensor (#4907)
- Add support for inverted buttons and inverted buttons without pullup (#4914)
- Add support for Luminea ZX2820 Smart Socket with Energy monitoring (#4921)
- Add support for multiple ADS1115 I2C devices (#5083)
- Add support for online template change using command Template or GUI Configure Other (#5177)
- Add support for Korean language translations (#5344)
- Add support for sensor SCD30 (#5434)
- Add parameter CFG_HOLDER to status 1 message (#5206)
- Add SetOption32 until SetOption49 diagnostic information to Status 3 report as replacement for second property value in SetOption property name
- Add Resolution property to Status 3 report providing previous SetOption second value property
- Add property MqttCount to status 6 message representing number of Mqtt re-connections
- Add property LinkCount to state and status 11 message representing number of Wifi Link re-connections
- Add property Downtime to state and status 11 message representing the duration of wifi connection loss
- Add variable %timestamp% to rules (#4749)
- Add rule support for "==", "!=" ">=" and "<=" (#5122)
- Add rule expression enabled by define USE_EXPRESSION in my_user_config.h (#5210)
- Add Power status functionality to LED2 when configured leaving LED1 for Link status indication
- Add user configuration of HLW8012 and HJL-01/BL0937 Energy Monitoring as used in Sonoff Pow and many Tuya based devices
- Add user configuration of MCP39F501 Energy Monitoring as used in Shelly2
- Add online template configuration using both commands and Configure Template menu option in GUI
- Add (S)SerialSend3 escape sequence \x to allow hexadecimal byte value (#3560, #4947)
- Add define DS18B20_INTERNAL_PULLUP to select internal input pullup when only one DS18B20 sensor is connected eliminating external resistor (#4738)
- Add button control when no relay configured (#4682)
- Add startup delay of 4 seconds to button control (#4829)
- Add core version conditional compile options to provided PWM files (#4917)
- Add resiliency to saved Settings (#5065)
- Add MHZ19 Temperature as Domoticz Temperature selection (#5128)
- Add HAss status sensor (#5139)
- Add status message to former declined group commands (#5145)
- Add 0x to IRRemote (SetOption29) and RCSwitch (SetOption28) received hexadecimal data (#5431)
