Hi, Tasmota 7.1.0 (Betty) ist online:
edit: inzwischen Tasmota v7.1.1 (Betty) Release
und Tasmota v7.1.2 (Betty) Release
https://github.com/arendst/Tasmota/releases
.bin Download und OTA-link: http://thehackbox.org/tasmota/release/
Es gibt jetzt ein 'offizielles Upload-Tool': Tasmota PyFlasher
(Variante des NodeMCU PyFlasher, ohne die sonst nötigen Einstellungen)
Auffälligste Änderung ab Version 7 ist, wie schon an anderer Stelle beschrieben,
das "Dark theme" -> falls nach Update noch das helle Thema angezeigt wird,
kommt man mit WebColor 0 schnell zum dunklen Thema.
Außerdem wurde auch passend GitHub umgestellt (Black Friday ) https://tasmota.github.io/docs/#/Home
Changelog:
Spoiler anzeigen
Version 7.1.2 Betty
- Fix lost functionality of GPIO9 and GPIO10 on some devices (#7080)
- Fix Zigbee uses Hardware Serial if GPIO 1/3 or GPIO 13/15 and SerialLog 0 (#7071)
- Fix WS2812 power control (#7090)
- Change light color schemes 2, 3 and 4 from color wheel to Hue driven with user Saturation control
- Change log buffer size from 520 to 700 characters accomodating full rule text (#7110)
Version 7.1.1 Betty
- Fix slider for devices with one or two channels like only white or white/yellow
- Fix TasmotaSlave buffer overrun on Tele
- Fix light scheme 4 speed (#7072)
- Add support for TasmotaSlave executing commands on Tasmota
Version 7.1.0 Betty
- Remove update support for versions before 6.0
- Remove driver xsns_12_ads1115_i2cdev replaced by xsns_12_ads1115
- Remove most IR protocols from non dedicated IR firmware except NEC, RC5 and RC6
- Change repository name from Sonoff-Tasmota to Tasmota and all code references from Sonoff to Tasmota
- Change documentation from wiki to documentation repository by @blakadder
- Change default GUI to dark theme
- Change ArduinoSlave to TasmotaSlave
- Change IRremoteESP8266 library to v2.7.1
- Change supported PCF8574 I2C address range to 0x20 - 0x26 allowing other I2C devices with address 0x27 to be used at the same time
- Change supported PCF8574A I2C address range to 0x39 - 0x3F allowing other I2C devices with address 0x38 to be used at the same time
- Change supported MCP230xx I2C address range to 0x20 - 0x26 allowing other I2C devices with address 0x27 to be used at the same time
- Change Reset erase end address from as seen by SDK (getFlashChipSize) to full flash size (getFlashChipRealSize)
- Change new Fade system much smoother, Speed now up to 40 (#6942, #3714)
- Fix better control of RGB/White when
SetOption37
>128, addedDimmer1
andDimmer2
commands (#6714) - Fix random crash caused by UPNP flood
- Fix check deepsleep for valid values in Settings (#6961)
- Fix Wifi instability when light is on, due to
Sleep 0
(#6961, #6608) - Fix auto-power on/off when setting channel to non-zero or zero value, when
SetOption68 1
- Fix postpone saving settings to flash until Fade is complete, avoids pause in Fade
- Add support for Tuya battery powered devices (#6735)
- Add support for Honeywell I2C HIH series Humidity and Temperetaure sensor (#6808)
- Add support for Honeywell HPMA115S0 particle concentration sensor by David Hunt (#6843)
- Add support for I2C sensor TLS2591 Light Intensity sensor (#6873)
- Add command
SetOption73 0/1
to re-enable HTTP Cross-Origin Resource Sharing (CORS) now default disabled (#6767) - Add command
SetOption74 0/1
to enable DS18x20 internal pull-up and remove define DS18B20_INTERNAL_PULLUP (#6795) - Add command
SetOption75 0/1
to switch between grouptopic (0) using fulltopic replacing %topic% or (1) is cmnd/<grouptopic> (#6779) - Add command
SetOption76 0/1
to enable incrementing bootcount when deepsleep is enabled (#6930) - Add command
SetOption77 0/1
to keep power on when slider is far left - Add command
I2cDriver
for I2C driver runtime control using document I2CDEVICES.md - Add command
TempOffset -12.6 .. 12.6
to set global temperature sensor offset (#6958) - Add command
WebColor19
to control color of Module and Name (#6811) - Add command
WifiPower 0 .. 20.5
to set Wifi Output Power which will be default set to 17dBm - Add frequency to ADE7953 energy monitor as used in Shelly 2.5 by ljakob (#6778)
- Add hide Alexa objects with friendlyname starting with '$' (#6722, #6762)
- Add Zigbee command support, considered as v1.0 for full Zigbee support
- Add hardware detection to be overruled with
SetOption51
(#6969) - Add Colorpicker to WebUI by Christian Staars (#6984)
