Hallo
Auf einem RPi 2B sind mehrere DS18B20 angeschlossen und diese sind in bus/w1 sichtbar.
Nun versuche ich diese in IOBroker auszuwerten. Leider gelingt es mir nicht den Adaptewr
OWFS zu installieren. Es erscheint die Fehlermeldung
"Fertig mit Fehler: host.raspberrypi Cannot install iobroker.owfs: 243".
IOBroker Version lautet ioBroker.admin 3.5.10
node/nodejs v.8.16
npm v.6.4.1
js-controller 1.4.2
Ganze Fehlerausgabe sieht so aus
iobroker 2019-05-19 09:21:27.942 info exit 25
iobroker 2019-05-19 09:21:27.919 error host.raspberrypi Cannot install iobroker.owfs: 243
iobroker 2019-05-19 09:21:27.858 info npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-05-19T07_21_27_726Z-debug.log
iobroker 2019-05-19 09:21:27.853 info
iobroker 2019-05-19 09:21:27.697 info npm ERR! the command again as root/Administrator (though this is not recommended).
iobroker 2019-05-19 09:21:27.697 info npm ERR! permissions of the file and its containing directories, or try running
iobroker 2019-05-19 09:21:27.697 info npm ERR! If you believe this might be a permissions issue, please double-check the
iobroker 2019-05-19 09:21:27.697 info npm ERR! It is likely you do not have the permissions to access this file as the current user
iobroker 2019-05-19 09:21:27.697 info npm ERR! npm ERR! The operation was rejected by your operating system.
iobroker 2019-05-19 09:21:27.691 info npm ERR! path: '/opt/iobroker/node_modules/readdirp/node_modules/braces/node_modules' }
iobroker 2019-05-19 09:21:27.691 info npm ERR! syscall: 'access',
iobroker 2019-05-19 09:21:27.691 info npm ERR! code: 'EACCES',
iobroker 2019-05-19 09:21:27.691 info npm ERR! errno: -13,
iobroker 2019-05-19 09:21:27.691 info npm ERR! stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/readdirp/node_modules/braces/node_modules\'',
iobroker 2019-05-19 09:21:27.691 info npm ERR! { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readdirp/node_modules/braces/node_modules'
iobroker 2019-05-19 09:21:27.691 info npm ERR! syscall accessnpm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readdirp/node_modules/braces/node_modules'
iobroker 2019-05-19 09:21:27.677 info npm ERR! errno -13
iobroker 2019-05-19 09:21:27.677 info ERR! path /opt/iobroker/node_modules/readdirp/node_modules/braces/node_modulesnpm ERR! code EACCES
iobroker 2019-05-19 09:21:27.670 info npm
iobroker 2019-05-19 09:21:20.229 info WARN checkPermissions Missing write access to /opt/iobroker/node_modules/readdirp/node_modules/braces/node_modules
iobroker 2019-05-19 09:21:20.212 info npm
iobroker 2019-05-19 09:20:10.728 info npm install iobroker.owfs --production --save --prefix "/opt/iobroker" (System call)
iobroker 2019-05-19 09:20:09.149 info NPM version: 6.4.1
iobroker 2019-05-19 09:20:04.537 info add owfs --host raspberrypi
Alles anzeigen
Mfg premo
